Power Steering Loss - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-19-2011, 04:08 PM   #1 (permalink)
View adria72's Photo Gallery
Power Steering Loss
I have a 2001 camry with about 88k miles on it. It's in great condition, but when it is cold out and even more so when it is wet and cold out, I lose power steering. Once the car warms up, it comes back. I have changed the belts a couple of times and thought about changing the rack, but I was told it wouldn't be the rack causing this problem. Any suggestions before I get hurt?
adria72 is offline   Reply With Quote
Old 01-19-2011, 04:17 PM   #2 (permalink)
Whats a Noobian?
sq_camry's Avatar
View sq_camry's Photo Gallery
happens to me every so often on my 98 LE, check your fluid levels and add some if you are low. could be that there is just a tiny leak somewhere too.
sq_camry is offline   Reply With Quote
Old 01-19-2011, 07:59 PM   #3 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
If it's not leaky seals then check the PS belt tension. An old belt stretches and doesn't grab the pulleys well. This is a problem when there are no automatic tensioners.
If the problem goes away after adjusting tension then you know. It would be time to put on a new belt and maybe do a complete timing belt job too.
Old 01-19-2011, 10:49 PM   #4 (permalink)
#2!
Gameroom cash: $102128
View #2!'s Photo Gallery
Funny
This reminded me of having the same problem with my Dodge Ram 3/4 ton. The really BIG problem was that on Cummins engines they use the power steering pump to provide the brake boost. So once in a while on a cold morning I put it in reverse and then realize I had no brakes. The peddle was rock solid and wouldn't budge. It took 3-4 attempts to slam on the e-brake and always had to check my pants after.
It always had a full fluid level and it is driven by one of the timing chains so theres no way it could have been slipping.
I sold that POS before I put it through a brick wall.
#2! is offline   Reply With Quote
Old 01-20-2011, 10:01 AM   #5 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135123
View Hajoca's Photo Gallery
Cold, thick fluid is hard to pump. Normal for cold mornings.
In my CE, i used Mobil1 ATF, and it does flow better than my XLE which I filled with PS Fluid.
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
Old 01-20-2011, 11:40 AM   #6 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140495
i concur about the belt tension. if i drive through a deep puddle on the passenger side i have the same problem.
Old 01-20-2011, 02:14 PM   #7 (permalink)
SE V6 5spd aficionado
mazdaverx7's Avatar
Gameroom cash: $142520
View mazdaverx7's Photo Gallery
it depends of if you have a complete power steering loss of if its just slightls tougher than normal. often times the power steering pressure sensr will show signs of failure this way. sometiems it will work when cold other times when hot. you may also want to clean and regrease your steering u-joints. they can start to bind and when cold will give you a false sense of steering boost loss.
92 Camry SE 3VZ-FE 5spd 131K 6m1
85 Porsche 944 119K 5spd
88 RX-7 10AE 96K 5spd
85 RX-7 GS 5spd
05 RX-8 38K 6spd, 63 Ford Falcon 99K I6 3spd
mazdaverx7 is offline   Reply With Quote
