The unit is a plx m300. I always use a Wideband for ANY forced induction tuning. This is the 2nd m300 I have used. My first one has been in 5 different vehicles and still works great. It is currently in my Conquest now. It reads out the word "lean" or "rich" if it goes to far either way.
Here it is just for testing now gotta hide it a lil better. Factory 5sp goodness.
I will be putting the display in the factory clock location. Plx units are a rectangle box with the guts placed inside. The unit can be taken apart and the display unsoldered then a length of wires soldered in between the unit and the display. This allows a remote mounting of the display into a smaller area wher the box would not fit. So I have to pull the plastic surround to see if behind the factory clock will fit with or without the display intact.
Here is a pic of the remote mounted display in my conquest. I reused the display of the plx instead of the clock display. The plx m300 box with the guts is hidden behind the glovebox. Evo 9 gauges
Here is the factory clock spot I will be mounting the display.
Check out the cut out spider conquest hood in background.
They have a 2 wire hookup for power. Switched ignition power and ground-earth. There are couple other wires for factory o2 output.
