Originally Posted by Makincold
1997 Camry LE 2.4 auto 221,000 miles
...221K, Im the second owner, bought at 174K 3 years ago. Engine uses about 1/2 quart of oil between 5K synthetic oil changes, but has recently dropped from 27MPG to 25MPG
Car is in good shape, 4 new tires, new radiator, new CV's, very good interior
Do I stick with a "known" engine with 221K or go with a unknown lower mileage engine?
Thanks!
How long do you expect to keep the car? Based on your description, the car is in good shape, with no obvious issues with the engine. I would assume the timing belt and associated seals and hardware have been replaced relatively recently, and there are no upcoming major service items. If so, the trans replacement would only indicate a rear seal replacement - and that's 'while you have it apart' kind of item.
Before making a final decision, I'd do a 'full diagnostic' on your current engine - cylinder leak-down, cooling system pressure check, oil pressure check/oiling system system leak-down, close exam of all gaskets, etc. If all checks as good, just swap the tranny, and enjoy. If not, cost out the repairs needed.
Bottom like - if the current engine is in good shape, leave it alone. Replace only if there are issues the replacement can address.
