do I need to change the dogbone? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-22-2011, 02:24 PM   #1 (permalink)
View microsat's Photo Gallery
4th Generation do I need to change the dogbone?
when stopping at a red light, I can feel a little bit vibration coming from the cushion and steering wheel.
I am attaching the two pictures of dogbone. You can see there is
a small crack in the dogbone. but do I need to change the dogbone now?
or can I wait till the summer?
thank you.
microsat is offline   Reply With Quote
Old 01-22-2011, 02:46 PM   #2 (permalink)
Chemist at Chevron
Gameroom cash: $315485
View bdy0003's Photo Gallery
I dont know about Gen 4s, but Gen 3s will have that vibration despite having good motor mounts. Your dogbone looks like its deteriorating some, but I would leave it for now. Chances are if your dogbone needs replacing, your other motor mounts need replacing.
95 Camry LE I4 195k
bdy0003 is online now   Reply With Quote
Old 01-22-2011, 02:51 PM   #3 (permalink)
Operator / Diesel Tech
Mister_Perkins's Avatar
Gameroom cash: $601601
iTrader Score: 6 reviews
If anything, you can fill the mount up with some fillable rubber (3m makes good epoxy). This will strengthen it a little and help it last a bit longer.
The Following User Says Thank You to Mister_Perkins For This Useful Post:
doozergreengrass (01-22-2011)
Old 01-22-2011, 04:42 PM   #4 (permalink)
Toy Nut
OceanView's Avatar
Gameroom cash: $105050
View OceanView's Photo Gallery
It looks ok to me.
How many miles on your car?
Could be other mounts.
1MZ-FE - 305,xxx Miles
OceanView is offline   Reply With Quote
Old 01-23-2011, 01:04 AM   #5 (permalink)
Freakin Scooters
LynchburgCSI's Avatar
Gameroom cash: $1409695
iTrader Score: 16 reviews
If the dogbone is getting worn, that's usually a sign that the other motor mounts are getting worn too. That one looks decently worn, but I wouldn't say that it needed to be replaced. How many miles are on the car?
'07 Honda Ruckus Big Bore
Old 01-23-2011, 01:54 AM   #6 (permalink)
71Corolla's Avatar
Gameroom cash: $548750
View 71Corolla's Photo Gallery
That thing needs to be changed yesterday it's shot. They are not expensive, and I've even seen good ones at the salvage yards.
71Corolla is online now   Reply With Quote
Old 01-23-2011, 11:10 AM   #7 (permalink)
It is 110K miles now.
Old 01-23-2011, 01:20 PM   #8 (permalink)
Freakin Scooters
You're probably fine. Don't worry about it for now. Check back if it gets worse.
Old 01-23-2011, 11:41 PM   #9 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
How's the jolt of shifting from N into D or R?
I'd replace the mount. It's about $30 online. You may be able to get an OEM one from one of the sponsors here at a similar price. And you can do it yourself. But the thing would be to check the main engine mounts. You also should make sure the engine is well tuned.
Old 02-06-2011, 01:59 PM   #10 (permalink)
View kjarrett's Photo Gallery
I'm in the same boat. '97 4 cyl. w/212k on the clock. I'm getting vibbration at idle in Drive. What do you all think? -kj-
'05 Rav4 L
'97 Camry LE
kjarrett is offline   Reply With Quote
Old 02-06-2011, 02:06 PM   #11 (permalink)
Freakin Scooters
^ Trashed. Time for a change if it's in the budget. Also check your other engine mounts. One failed = possible excessive wear on others.
Old 02-06-2011, 03:52 PM   #12 (permalink)
Gameroom cash: $153405
View redgtxdi's Photo Gallery
Ditto for mine ('98 LE 2.2L 4-auto). But regarding the other mounts.....I can easily see the one in the lower front. Where are the others??
And if all those are worn, then why not:
Trans mounts
Rear control arms
Trailing arms
Sways
Links
Tie rod ends
axles
etc.
etc.
Basically....everything that's rubber needs to go!
So about after you either spend $1 to $2K in parts & $1k of your labor (or your death if it drives you insane enough)......or $5K at a shop to have all that done........you might as well go buy a new car, eh??
1998 Camry 2.2L auto. 195,000 "mostly" trouble-free miles. She needs a little work but still purrs.
1995 Geo Prizm 1.6L. 165,000 "mostly" trouble-free miles. (need to sell soon)
2011 Venza 2.7L. 5,000 miles wondering if there ever was an NVH crew assigned to Venza
redgtxdi is offline   Reply With Quote
Old 02-06-2011, 04:00 PM   #13 (permalink)
Avy
Gameroom cash: $818655
View pmesfun's Photo Gallery
Trans mounts
Rear control arms
Trailing arms
Sways
Links
Tie rod ends
axles
etc.
etc.
I need most of those replaced, axles, you can get the boot kits from Toyota. IIRC Trailing arms need to be purchased from Toyota also or Energy Suspension sells a kit which I think includes the bushings for the arm.
edit:
ES Page for you Camry
http://www.energysuspensionparts.com...ota+Camry+1998
99 Avalon XLS-149k
07 Avalon Touring-71k
99 Lexus LS400-88k
04 Nissan Quest-111k
pmesfun is online now   Reply With Quote
Old 02-06-2011, 04:18 PM   #14 (permalink)
OH ya........I forgot ball joints too!! Heck, what about bearings? & new paint. Struts. Trans flush. PS flush. Brake fluid flush. etc.
Or save yourself all the grief.........
with THIS
Old 02-06-2011, 05:40 PM   #15 (permalink)
Freakin Scooters
with THIS
