2000 Camry XLE V6 (usa):
Just had my power steering fluid flushed. After that was done, my steering wheel squeaks when I turn it, sometimes. Usually the turn has to be extreme to hear the squeak, but it's definitely there and it definitely sounds like it's coming from the steering wheel (or at least somewhere in that general area, but not from like the fan belt or anything outside the car or under the hood).
Is it possible that new steering fluid would somehow "unearth" a problem that was always there but hidden somehow by the old fluid?
If the mechanic used something other than the recommended Dexron III (per Haynes manual), would it cause the problem? Would that be an issue in general to not use Dexron III (I think they said they use something called Omni on all cars across the board, but I'll call them to dbl-check)
Finally, I brought it back to the mechanic and let him hear the sound and he said he heard it when driving the car into the shop from the parking lot before even doing the flush (I find this hard to believe), and also said it's common with the older Camry's to have a squeaking steering wheel, that it has something to do with the bearing inside the actual steering wheel which needs to be lubed potentially...
I tried this solution by the way (with silicone spray, not wd-40) and it didn't solve it, I'll try it once more though:
http://www.instructables.com/id/How-...ay-WD-40-Here/
