The old 3vz fe y-pipe? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-23-2011, 03:53 PM   #1 (permalink)
Domesticon Prime
Gameroom cash: $206500
View Silent Runner's Photo Gallery
Allright, a big long forum search tells me that replacing the y-pipe is one of the very best mods we can make to these engines and cars, yet it also suggests that it's nearly impossible to find a better one pre-made that will really fit/may be of poor quality..etc. I would like to buy one and take it my local shop to be installed. Has anyone on the forum found a good solution to this challenge, or am I going to have to go the long route and have it custom made? I was thinking of going to the local Pick-and Pull, buying a stock one and having a shop fab one up (without Toyota's, "Much Sake" induced origami design) that would match its clearance points and simply bolt-up to the pre-cat mounting point. Has anyone, more resently found a better way of making this happen?
Domesticon Prime
93' LE V-6, 303K Km., fully optioned including Leather Interior. ES300 rear discs, twin piston front calipers, Depo Chromes with HID projectors, 17" OZ' summer's, 96 corner lights, MAF, timing, exhaust and intake mods, 2001 Toyota/JBL sound, + more and always more coming.
Silent Runner is offline   Reply With Quote
Old 01-23-2011, 04:00 PM   #2 (permalink)
How hard can it be?
BlueFusion6851's Avatar
View BlueFusion6851's Photo Gallery
Fabrication will yield the best results for how far you intend to go with your engine. With that said, the oem y-pipe will be a good point of reference like you said. Good Luck!
BlueFusion6851 is offline   Reply With Quote
Old 01-23-2011, 04:09 PM   #3 (permalink)
View camry6's Photo Gallery
Canada
I am going to cut the rear bank pipe off just pass the turn that comes down from the manifold. Then I'm going to cut the pipe from the front bank just before the "T" intersection for the rear bank. The down pipe from the rear bank can then be turned around at the manifold which will point the opening toward the rear of the car. Join in two lengths of pipe and merge them together right before the cat and "Bob's 'yer uncle"........at least I think it'll be that easy, I have already tested the cut pipes and their configuration, I just haven't put it all together yet .
1993 Toyota Camry V6 LE (200 HP, 195 ft/lbs tweaked) , 430,000 km's.
2002 Lexus GS 430 V8 VVT-i (300 HP, 325 ft/lbs) Luxury with Mark Levinson , 156,000 km's
2006 Lexus ES 330 V6 VVT-i (225 HP, 250 ft/lbs) Premium Luxury, Sport, Navigation with Mark Levinson , 140,000 km's
camry6 is offline   Reply With Quote
The Following User Says Thank You to camry6 For This Useful Post:
Silent Runner (01-23-2011)
Old 01-23-2011, 04:28 PM   #4 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
another good reference is the "Dat's Style" y-pipe popular on solaraguy. Very simple Collector design and works well.
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 01-23-2011, 04:30 PM   #5 (permalink)
Domesticon Prime
I think alot of these cars are only just now really being turned over to the next/current generation of enthusiasts and tuners. They were so reliable and well built that alot of families held on to them as second cars, passed them along to family members or delayed replacing them for a long time.(or so the local Toyota Dealers told me) I rarely ever saw them show up at the local Pick-and Pull, until two years ago. This is a good time to offer-up or dig-up simple solutions to a generation of beginner enthusiasts. The cars are pretty cheap, and a couple of simple things can add 30hp to their output and push them into a pretty decent performance zone. I'm going to take mine a little further, but I want to take baby steps and not blow up things like transmissions along the way. Lets fix the y-pipe!
Domesticon Prime
Old 01-23-2011, 05:21 PM   #6 (permalink)
Freakin Scooters
LynchburgCSI's Avatar
Gameroom cash: $1409695
iTrader Score: 16 reviews
Check out EEngineer's for sale thread. He has a custom 3vz y-pipe fabbed, IIRC. You could at least copy the design.
'07 Honda Ruckus Big Bore
The Following User Says Thank You to LynchburgCSI For This Useful Post:
Old 01-23-2011, 06:09 PM   #7 (permalink)
Domesticon Prime
I'm going to have to look at that darn thing (the OE one) again, but even EEngineers y-pipe design seemed to have the rear bank firing right back at/into the front bank. And geez! why did I look... he's got all the stuff for the 5spd. thing, and a frigging supercharger sitting right there taunting me!
I missed why he's doing this, did he get married or something?
Domesticon Prime
Old 01-23-2011, 06:27 PM   #8 (permalink)
View 1BADBAJA's Photo Gallery
It sounds like Camry6 has the right idea. If it were me I would try to retain a flex pipe before the "Y" is welded together. It will make removing it from the motor easier like factory.
A person could also run true dual exhaust side by side for how ever far back and do a "x" pipe, 2 into 1, or whatever setup you could imagine with 2 pipes.
What size is the pipe coming down off the factory header after the flange?
1BADBAJA is offline   Reply With Quote
Old 01-23-2011, 07:19 PM   #9 (permalink)
Domesticon Prime
I like Camry6's idea as well. from what I've read it is important to retain a flex pipe section for each cylinder bank. Then would do a simple 2 into one merge just before the cat. or whatever mounting point as he is doing. I don't know how to post the great tuning link I was reading on this, but I don't think doing a dual exhaust system would provide any real benefits. It might look and sound cool, but it will also add cost, weight and complexity.
As I think about it, this silly OE design was probably intended to generate backpressure and heat, to light-off the cat. converter faster for emissions reasons.
I haven't measured the pipe diameter of the exhaust header pipes
Domesticon Prime
