Front wheel bearing Camry V6 99 (Aus) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-24-2011, 06:57 AM   #1 (permalink)
View ednik's Photo Gallery
When I put my Camry V6 1999/199000km (Australia) in for a major service last year the vehicle report came back with "Minor play in Front Wheel Bearings", amongst other things.
My question is when should I get them done ?
Ive jacked up the car and spun both wheels, there is no grinding/crunching noise but I do notice a little shimmer through the wheel when braking lightly at 60kmh ? Is this a sign that my bearings are giving way ?
Ive got new pads and discs on so I dont think its warped discs or uneven pads ?
How much would I be looking at roughly to get them done through a garage ?
Thanks.
ednik is offline   Reply With Quote
Old 01-24-2011, 08:24 PM   #2 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
Sure. If the play in the bearing is more than 0.010" (~.254mm) then they should be replaced.
In the US it's about $32 USD each. A shop can properly press out the oil bearing and the new one back in for about $30-40 USD if you bring them the knuckles (~$150 both sides). There are also rental tools allowing the DIYer to do the bearing swap.
http://www.honda-tech.com/showthread.php?t=1996133
However, if you need to have the shop remove/install the steering knuckle, then my guess is about 2 hours of labor plus the cost of the parts? Depending on the labor rate, maybe $200-300? Not all shops can properly do a bearing swap so be careful where you go.
Thanks.
Old 01-31-2011, 05:51 AM   #3 (permalink)
Thanks for the nice suggestion JohnGD, gave me good idea of what I'm up against.
I actually phoned around and average cost all up was 160 AUD each side and 200 AUD Labour on top of all that - so about 520 Aud all up, I pulled the trigger anyway and she's all booked in.
Cheers.
