PS Pump still leaking! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-24-2011, 04:35 PM   #1 (permalink)
Avy
Gameroom cash: $818655
View pmesfun's Photo Gallery
I replaced the o-ring that I thought was leaking and put some RTV to make sure it never leaks again. Went to start the car and its STILL leaking. Turns out it the front seal for the shaft, which I already replaced. Is there some special RTV to use on this seal, so it will stop leaking for sure?
99 Avalon XLS-149k
07 Avalon Touring-71k
99 Lexus LS400-88k
04 Nissan Quest-111k
pmesfun is online now   Reply With Quote
Old 01-25-2011, 12:01 AM   #2 (permalink)
Avy
Any special RTV?
That's what I've been using.
99 Avalon XLS-149k
99 Lexus LS400-88k
Old 01-25-2011, 12:04 AM   #3 (permalink)
71Corolla's Avatar
Gameroom cash: $548750
View 71Corolla's Photo Gallery
It's possible the shaft itself has a groove in it, or is damaged. You can't put sealant there because of the rotation. Are you certain it is leaking from the seal? Or unless you mean put RTV on the outer edges of the seal?
The RTV you are using is fine.
71Corolla is online now   Reply With Quote
Old 01-25-2011, 12:11 AM   #4 (permalink)
Avy
That is what Gary(toyotapartsman) said. I guess it is damaged then because I replaced everything, and that seal included. I can actually see it dripping immediately after I refill the pump and when the car is on. Yeah, I would want to put rtv anywhere that isn't moving. Planning on replacing the seal and if it still leaks, then I'll have to replace the shaft.
99 Avalon XLS-149k
99 Lexus LS400-88k
Old 01-25-2011, 12:16 AM   #5 (permalink)
71Corolla's Avatar
If you can, pull the pump apart and inspect it. If the shaft is good then what else could it be? I would hit a salvage yard. I would imagine in your area you have many choices.
The Following User Says Thank You to 71Corolla For This Useful Post:
pmesfun (01-25-2011)
Old 01-28-2011, 06:49 PM   #6 (permalink)
Avy
Why it was leaking...
Yes, I know...FAIL.
The seal I got this time seems a little different, more rubber that metal?
I am going to order a rebuilt kit again, and buy the shaft. There are two groves on it.. I guess somehow I broke that metal o-ring. What places would I be safe to apply RTV?
99 Avalon XLS-149k
99 Lexus LS400-88k
Old 01-28-2011, 07:21 PM   #7 (permalink)
Operator / Diesel Tech
Mister_Perkins's Avatar
Gameroom cash: $601601
iTrader Score: 6 reviews
I'de put it on the outside if anything because the shaft will be spinning and wouldn't do anything on the inside
The Following User Says Thank You to Mister_Perkins For This Useful Post:
pmesfun (01-28-2011)
Old 01-28-2011, 08:24 PM   #8 (permalink)
71Corolla's Avatar
You could put RTV on the outside, but there is no sealant there from the factory so I don't see why it would be needed.
Old 01-28-2011, 08:38 PM   #9 (permalink)
Avy
I just want it to never leak AGAIN. Called the dealer, gasket kit is in stock, shaft needs to be ordered. I will be calling the other dealer tomorrow.
99 Avalon XLS-149k
99 Lexus LS400-88k
Old 01-28-2011, 08:39 PM   #10 (permalink)
if the shaft is within spec as far as OD, theres no reason it should leak unless the seal is driven in incorrectly
Old 01-28-2011, 08:48 PM   #11 (permalink)
Avy
I thought it can still leak from the grooves on the shaft? I just don't want to take a chance again, actually get tired of working on the car.
99 Avalon XLS-149k
99 Lexus LS400-88k
Old 01-28-2011, 09:25 PM   #12 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
As mentioned, only on the outside.
ATF attacks RTV, and if applied on the inside can cause it to come loose into the system and plug up something. That's a reason why ATF pan gaskets are cork-rubber or all-rubber.
Old 01-28-2011, 11:01 PM   #13 (permalink)
Avy
So basically what you are saying is not to put any RTV because if theirs a leak, the RTV will be eaten away?
99 Avalon XLS-149k
99 Lexus LS400-88k
Old 01-28-2011, 11:24 PM   #14 (permalink)
No need for RTV. The seals and gaskets should properly seal the system. Please torque properly using a torque wrench.
(this is also a perfect example why oil seals should be replaced when doing the timing belt at 5-year/60K miles ).
Old 01-28-2011, 11:26 PM   #15 (permalink)
71Corolla's Avatar
RTV is commonly used in automatic transmissions and differentials. Permatex makes a version specifically designed to be resistant to ATF, although I can't see it being much different than the other RTV's out there.
But I agree, there is no RTV from the factory so it is not needed.
JohnGD (01-28-2011)
