Injen intake or no ? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-25-2011, 06:34 PM   #1 (permalink)
View black98camryv6xle's Photo Gallery
4th Generation Injen intake or no ?
Is it worth to get a injen intake for my camry? been debating this for a while but i dont know if i should
black98camryv6xle is offline   Reply With Quote
Old 01-25-2011, 10:17 PM   #2 (permalink)
Freakin Scooters
LynchburgCSI's Avatar
Gameroom cash: $1409695
iTrader Score: 16 reviews
Assuming a '98 1MZ auto here. All it's going to do is add noise. People have done some dynos, and there's no gain, IIRC. Note that the factory intake is already a cold air intake (CAI). Switching to a short ram intake (SRI) is just going to raise your intake air temps.
'07 Honda Ruckus Big Bore
Old 01-26-2011, 05:12 PM   #3 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
first off, avoid such large font. its annoying to read. seccond, if your going to get an intake teh injen is a pretty good one to get. you can find extentions that allow you to convert to a CAI (if you cant just make one your self) and its got a descent quality filter with it. like Lynch said, it will prove no gains but sounds AMAZING on the v6.
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 01-26-2011, 05:23 PM   #4 (permalink)
Freakin Scooters
As always, I agree with Rob.
Old 01-26-2011, 09:02 PM   #5 (permalink)
so what would be good for gains in power ?
Old 01-26-2011, 09:06 PM   #6 (permalink)
Freakin Scooters
OBX y-pipe and headers. 5-speed swap. Supercharger. Search around... there's good info on modding the 1mz-fe.
Old 01-26-2011, 09:16 PM   #7 (permalink)
redneck engineer
lemegacool's Avatar
Gameroom cash: $233405
View lemegacool's Photo Gallery
3 inch cold air intake on a 1mz is stupid loud at WOT lol it make heads turn!!! damn i need to put up a sound clip of it !
also if you want free power: clean your intake plenum and egr system, relocate the knock sensors. this can give you up to 15 hp depending on the condition the plenum/egr was
1994 camry v6 5 speed swapped
holset hx35w rebuild/polishing in progress :P
cardomain: http://www.cardomain.com/ride/3872430
lemegacool is offline   Reply With Quote
Old 01-26-2011, 11:28 PM   #8 (permalink)
Gameroom cash: $811887
iTrader Score: 10 reviews
My CAI on the 1MZ is not even noticeable...weird...
Chris Crash is online now   Reply With Quote
Old 01-27-2011, 03:18 AM   #9 (permalink)
TN の がしょう
xpeed's Avatar
Gameroom cash: $589157
iTrader Score: 7 reviews
View xpeed's Photo Gallery
My intake is loud when I turn the engine over for a minute or two and then goes quiet. It makes that little air-sucking noise. After the car is warmed up, it's gone.
It's pretty loud though after you punch it over 4500rpm. I've noticed 2mpg gain after I installed the intake though.
1997 カムリ 5-spd *daily driver* Tokico HP - Tein S-Tech - TRD Kit - TRD FSB - ARC - 18" Enkei OR52 - Project Kics R40 - Custom Exhaust - Whiteline 20mm Rear Sway Bar
2003 Infiniti FX35 Sport Package - Metallic Copper
1996 Avalon MCX10 1MZ-FE
http://www.cardomain.com/ride/3900268/1997-toyota-camry
xpeed is offline   Reply With Quote
Old 01-30-2011, 09:05 PM   #10 (permalink)
even if theres no power gain would there be more response from the throttle since more air goes in ?
Old 01-30-2011, 09:44 PM   #11 (permalink)
Freakin Scooters
It's negligible. You'd get more from cleaning the TB.
Old 01-31-2011, 10:46 AM   #12 (permalink)
1MZ powered MR2
Jason.MZW20's Avatar
Gameroom cash: $226450
View Jason.MZW20's Photo Gallery
Yeah, sounds like a mini-wastegate or something letting the excess air out on upshifts with a 5-speed manual. Only when cold. It's probably from the IAC valve metering more air for cold start enrichment.
Mine is loud since it's right behind me, near the MR2's lower side engine compartment vent.
Either my MAF doesn't like it or my MAF is on its way out. I've registered between +14-25% LTFTs only at idle because the MAF reports around 2.6-2.9 g/s, when clearly the engine is ingesting more as the AFR sensors are readjusting the trims. I put in a spacer in front of the MAF and it improved a tad, though not much, so I'm putting it on my MAF going bad. I've already cleaned it about 500 times. It's as clean as can be. That or my MAF doesn't like the ported heads and the extra volume they flow. It's a really strange issue. I've logged it a few times and can't draw any conclusions. I'll try out another MAF and see what happens.
1991 Toyota MR2 V6
Ported, rebuilt 3.0L 1MZ
Fully OBDII compliant and California smog legal
Jason.MZW20 is offline   Reply With Quote
The Following User Says Thank You to Jason.MZW20 For This Useful Post:
xpeed (01-31-2011)
