Floor jack question - Toyota Nation Forum : Toyota Car and Truck Forums
Closed Thread
Old 01-25-2011, 06:50 PM   #1 (permalink)
View cccxyz's Photo Gallery
Floor jack question
I have a 94 camry wagon. I have a pair of Craftsman 3-ton jack stands and I use the scissor jack with it. It's a bit painful... but I am kind of reluctant to get a floor jack .
I just saw a 2-ton floor jack on craigslist for $10. I wonder if it is strong enough for my wagon? The wagon is about 3 ton, right? When lifting on one end, it should just be half of the total weight. In comparison, my scissor jack only says 1 ton ... so I guess 2-ton is good enough? After all, I will use the jack stands once the car is up.
cccxyz is offline
Old 01-25-2011, 07:06 PM   #2 (permalink)
Gameroom cash: $811887
iTrader Score: 10 reviews
It's good enough, yes. But I'm willing to bet it's one of those crappy "mini" floor jacks. Those things suck.
Chris Crash is online now
Old 01-25-2011, 07:14 PM   #3 (permalink)
Chemist at Chevron
Gameroom cash: $315485
View bdy0003's Photo Gallery
1 ton = 2000lbs
I don't know how much a wagon weighs, but a gen3 camry weighs 2900 which brings it to be approx 1.5 tons. ALSO, consider that that the jack is lifting a certain part of the car, not the entire car.
If you do buy the jack, make sure you know how to use it, and make sure that thing has oil. The last thing you want is the the car slamming to the ground because something wasn't right.
95 Camry LE I4 195k
bdy0003 is online now
Old 01-25-2011, 07:21 PM   #4 (permalink)
Operator / Diesel Tech
Mister_Perkins's Avatar
Gameroom cash: $601601
iTrader Score: 6 reviews
I think I have a Napa 3.5 Ton floor jack. Ive had it for a really long time so it may be some other brand. I lifted crap that was too heavy for it though so when it sits flat its tweaked up. lol.
But it works good for jackin the camrys up when checking brakes and stuff
I know for sure I have a Esco air floor jack at the shop for the trucks, but i'm not sure what brand the floor jack is there?. You'll never need a 50 ton jack though. lol
Mister_Perkins is offline
Old 01-25-2011, 07:28 PM   #5 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
The 2-ton jack is cheap. New Torins are occasionally on sale at Pep Boys for about $10-15. There are also 2-1/4 ones from parts stores that go up to 15" or so.
The 2-tons are only good to 12"-13". After my Crapsman 3 ton blew a seal I got a Harbor Freight 3-ton. It's heavy but works fine. But it's like $80 now, a lot of HF prices went up.
JohnGD is offline
Old 01-25-2011, 07:54 PM   #6 (permalink)
Freakin Scooters
LynchburgCSI's Avatar
Gameroom cash: $1409695
iTrader Score: 16 reviews
Originally Posted by bdy0003 View Post
1 ton = 2000lbs
That's a stripped base model DX with no a/c and a manual tranny. A typical Camry weights 3200. The wagons weigh a smidge more. Also... food for thought. I have this same jack, sold under a different name. I DO NOT recommended small jacks or used jacks.
Duralast, Built To....um....H*LL NO!
'07 Honda Ruckus Big Bore
LynchburgCSI is offline
Old 01-25-2011, 08:05 PM   #7 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140495
my honest opinion - dont buy used floor jacks, in particular the smaller ones. hydraulics leak over time so used ones could already be leaking or could fail in the near future. certainly they arent too expensive to take the chance. and a floor jack is well worth the investment.
ghettosled is offline
The Following User Says Thank You to ghettosled For This Useful Post:
LynchburgCSI (01-25-2011)
Old 01-25-2011, 08:32 PM   #8 (permalink)
Chemist at Chevron
Thanks for clearing that up.
95 Camry LE I4 195k
Old 01-25-2011, 09:55 PM   #9 (permalink)
Seems like it is really a bad idea to buy a used floor jack ... so scary ... is this a mini one?
http://www.tiikoni.com/tis/view/?id=ee4b083
cccxyz is offline
Old 01-25-2011, 09:56 PM   #10 (permalink)
Gameroom cash: $198666
View jkg065's Photo Gallery
"Floor Jack Pinch Weld Adapter" is a metal bar that replaces a floor jack saddle. It is similar to the top portion of a stock scissors jack used in conjunction with a floor jack to raise a car at the designated underbody points.
http://redmoonbay.com
search box: 677 or Floor Jack Pinch Weld Adapter
$&.$( ea. Located in Webster, FL. I have a pair shipped via USPS 4 day turnaround. (Rate was the same as UPS for us in area code 808 at one time) Brand name: GRIP, Grand Rapids Industrial Products, #44577, Made in China. From what I can determine this is the same item as on other sites but at a more affordable price!
'04 Nissan Altima 3.5SE
'08 Corolla CE (wife's)
jkg065 is online now
Old 01-25-2011, 10:11 PM   #11 (permalink)
I wouldnt lift a 3rd gen camry by the pinch weld.
I always lift by the frame rails.
pinch welds are iffy. Especially in the salt belt
Old 01-25-2011, 10:24 PM   #12 (permalink)
Freakin Scooters
YES. Don't buy that.
Old 01-26-2011, 10:19 AM   #13 (permalink)
View LVLT FIXIT's Photo Gallery
New only - unless you know the seller personally. The o rings wear due to poor machine surface and clearance inside of the cheap jacks. Check how high and low the new one goes. Think of the future -what type car truck you may have and think of your future with a flat head. Damages can occur when lifting even when the jack stand are in place. I never skimp on safety items. Never use those cheap sheet metal rivited type jack stands! Torin is a good brand.
LVLT FIXIT is offline
Old 01-26-2011, 03:39 PM   #14 (permalink)
Gameroom cash: $470955
View carsrus's Photo Gallery
If your gonna be lifting small cars (Camry V6 and smaller) just get yourself a 2 1/4 jack from craftsman. There on sale all the time for 25-30. Mine worked great untill I tried jacking up my friends pathfinder and it started to leak. It still works to lift the camry though, but it blows by pressure slowly.
So all in all its not to shabby quality wise, only a couple bucks more than harbor freight.
carsrus is offline
Old 01-26-2011, 04:57 PM   #15 (permalink)
Freakin Scooters
2 1/4 ton... pathfinder... I wouldn't DREAM of using my 2 1/4 ton on my truck.
Closed Thread
