gen 4 motor mount torque specs - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-26-2011, 01:55 PM   #1 (permalink)
Gameroom cash: $326045
View adalex's Photo Gallery
4th Generation gen 4 motor mount torque specs
I have a gen 4 99 I4
I took off the dogbone mount and the bracket that holds it today to take off the valve cover and can't find the torque specs for the two bolts or the mount that it goes in
adalex is offline   Reply With Quote
Old 01-26-2011, 02:14 PM   #2 (permalink)
Freakin Scooters
LynchburgCSI's Avatar
Gameroom cash: $1409695
iTrader Score: 16 reviews
I don't think it matters much... good and tight. You should be able to judge roughly how much force you should apply from how much force it required when you took the bolts out.
'07 Honda Ruckus Big Bore
Old 01-26-2011, 04:12 PM   #3 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
both bolts in dog bone are 47ft-lbs per Haynes
bolts of its bracket to engine are 38ft-lbs.
