215/60R15 fit a 98? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-27-2011, 05:35 AM   #1 (permalink)
Gameroom cash: $177000
View ShawnTRD's Photo Gallery
215/60R15 fit a 98?
I got some stock 15" 97 Steelies with 205/65 snows on it now. In the spring I want to pull them off and run All Season. Will 215/60R15 fit? Looks to be the same diameter, but I'm afraid I'm pushing the width. Figuring my stock was 195/70R14.
MY 1998 Toyota Camry LE
http://www.toyotanation.com/forum/sh...d.php?t=368035
ShawnTRD is offline   Reply With Quote
Old 01-27-2011, 09:27 AM   #2 (permalink)
How hard could it be?
uibalnme's Avatar
Gameroom cash: $445645
View uibalnme's Photo Gallery
http://www.rimsntires.com/rt_specs.jsp
"True terror is to wake up one morning and discover that your high school class is running the country." - Kurt Vonnegut
Cardomain: 1)96 Toyota Camry LE 2)1965 Ford Mustang 3)1998 Toyota Sienna XLE
uibalnme is offline   Reply With Quote
The Following User Says Thank You to uibalnme For This Useful Post:
LynchburgCSI (01-27-2011)
Old 01-27-2011, 04:48 PM   #3 (permalink)
Ok let me ask it this way.
What size 15" tires have people run without a problem? And where you stock ride height, or lowered? And if lowered how much?
Old 01-27-2011, 04:52 PM   #4 (permalink)
If that website is right looks like I can run 225/60 15. Anyone have that size?
Old 01-27-2011, 06:43 PM   #5 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
Solaras use stock 205/65/R15 (or 205/60/R16) so I think you're OK on camry with 215/60/R15 with no problems at all.
Old 01-27-2011, 07:39 PM   #6 (permalink)
View heyitsdatguy's Photo Gallery
Offset is everything. With the right offset you can fit any tire size and wheel width. Learn your offset and go lower if needed to fit wider tires and wheels.
heyitsdatguy is offline   Reply With Quote
Old 01-27-2011, 08:43 PM   #7 (permalink)
I don't really want to go lower, but it's nice to know I could. I would most like to improve the cornering, but not loss the nice ride.
Old 01-27-2011, 09:57 PM   #8 (permalink)
抵抗は無駄です
fenixus's Avatar
as much as like the looks of lowered cars I simply cannot do it in my area!
this is how lowered Celicas look alike around my apartment complex (and there is a few of them, all have bumpers damaged in similar way):
also almost all of those lowered cars are sitting ducks when blizzard comes in ...
I can't lower my daily driver :crying:
Old 01-28-2011, 08:34 PM   #9 (permalink)
Domesticon Prime
Gameroom cash: $206500
View Silent Runner's Photo Gallery
I've looked into that size/rim/profile question myself. Yes they will fit, but that is really too wide of a tire to put on a 6" wide stock wheel. It will not provide a good mounting base for the tire. The tire will "balloon", or bulge out from the rim too much, and will not make the car handle properly. You need at least a 15X7" rim to mount that tire properly. The clearances are also already tight between strut towers and other suspension components. Think about the diameter of your "pinky" finger, now add a wider bulging tire. My thoughts have been about giving the car a nice 215/60 footprint, on top of filling out the wheel wells with a set of rims (15X7) that push out the track width a full inch on both sides + fatten the tire profile from 65 to 60, for a little sharper handling. With a rim that keeps the same offset as stock but adds the 1" of width on the outside of the rim, you solve the bulging tire problem, keep your clearances, height/speedo numbers and ride close to stock, gain in footprint and track width, and keep the silly cheap price of 15" tires!
Domesticon Prime
93' LE V-6, 303K Km., fully optioned including Leather Interior. ES300 rear discs, twin piston front calipers, Depo Chromes with HID projectors, 17" OZ' summer's, 96 corner lights, MAF, timing, exhaust and intake mods, 2001 Toyota/JBL sound, + more and always more coming.
Silent Runner is online now   Reply With Quote
