92 Camry V6 using LOTS of oil - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-27-2011, 01:28 PM   #1 (permalink)
View larrybum's Photo Gallery
Unhappy 92 Camry V6 using LOTS of oil
My camry was doing fine until I loaned it to someone who drove it too much after a head gasket began leaking. I'm sure the car was seriously overheated.
The car sat in my yard through the winter until I could get to a repair. It sat 9 months or so.
I replaced the head gaskets, water pump, and timing belt. I found about 1/2 of the head bolts on one head to be pretty loose as if someone had done this job before (car had close to 200k on it)...I am not the original owner.
In making the repair, I made the stupid mistake of swapping the head gaskets so that water would not circulate in either head. I drove the car about 3 miles and it overheated...much like a teakettle boiling over. I finally figured out what was wrong and did the whole job again.
I drove the car for a few thousand miles and don't remember excessive oil use, but I did go through a period of excessive gasoline use and heavy smoking intermittently when the car was started. Sometimes it ran on 5 cylinders when one of the cylinders was drowned out with gas. Finally traced that to a faulty engine computer that was turning on one or more of the injectors all the time. Got that replaced and then noticed heavy blue smoke which could have been there before...can't be sure since it may have been mixed with black smoke of a too rich mixture.
Some time following that major fix, I noticed it was burning oil at startup and the car was smoking for about 2 minutes or so after first startup in the am. It was blue smoke and it smelled like oil burning. It has been doing this since...I can't tell exactly when this started happening.
The oil consumption is about a quart in 300 miles or less. I get much less consumption on a longer trip, but around town it just gulps the oil, so I think it is really using the most oil when it is first atarted in the morning.
The smoke is not immediate. It takes about 10-15 seconds to begin and it is heavy and smellable for about 2 minutes.
There is no noticeable blowby, so it appears to be simply burning the oil in the combustion chamber. I am baffled as to what could be the issue. Am thinking carboned/stuck oil rings, but I've changed oil regularly and have had no other issues.
Other things: it seems like it has less power than before the head job repair...less pickup.
I've used seafoam with no noticeable improvement.
Could I have done something wrong during the head job that would somehow cause heavy oil use while the care is very cold???? But, later in the day, there is nothing noticeable being burned???
Any ideas on what it could be beyond the obvious....ring job.
larrybum is offline   Reply With Quote
Old 01-27-2011, 01:35 PM   #2 (permalink)
Operator / Diesel Tech
Mister_Perkins's Avatar
Gameroom cash: $601601
iTrader Score: 6 reviews
If you didn't re-surface your heads then I would say the heads warped from overheating and are not sealing against the head gasket. You cannot re-use a gasket once the motor heats up
edit:
you actually aren't supposed to re-use it once you torque it down. I'm pretty sure the head bolts are supposed to be replaced too. On the 5sfe anyways its recommended
Old 01-27-2011, 01:35 PM   #3 (permalink)
1MZ powered MR2
Jason.MZW20's Avatar
Gameroom cash: $226450
View Jason.MZW20's Photo Gallery
So did you re-use the gaskets you put on wrong or did you get new ones?
Have you checked the block and heads for warpage?
1991 Toyota MR2 V6
Ported, rebuilt 3.0L 1MZ
Fully OBDII compliant and California smog legal
Jason.MZW20 is offline   Reply With Quote
Old 01-27-2011, 02:01 PM   #4 (permalink)
Oil Consumption issues
maybe I was unclear. I did not reuse a head gasket. I bought a new set and put them in their proper locations. No overheating afterward.
Some have suggested a warped head. I am confused as to how a warped head would cause excessive oil consumption. There is no overheating. There is no pressure I can find on either the crankcase (no blowby to speak of) or the water jacket...nothing.
A poor leak in a head gasket would lead ot oen of those symptoms and the car runs fine exept for the oil consumption. I think a warped head/block is not related to this problem.
Old 01-27-2011, 02:04 PM   #5 (permalink)
you re-used a head gasket??
Old 01-27-2011, 07:43 PM   #6 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
Do a compression check and see if the rings are in good shape. The valve stem seals may have been cooked and leaking oil. You might want to check oil pressure as well.
Old 01-27-2011, 09:21 PM   #7 (permalink)
71Corolla's Avatar
Gameroom cash: $548250
View 71Corolla's Photo Gallery
I saw this happen once, car pushed blue almost all the time and ate oil like crazy. But yes do a compression test for sure.
71Corolla is online now   Reply With Quote
Old 01-28-2011, 09:34 PM   #8 (permalink)
Domesticon Prime
Gameroom cash: $206500
View Silent Runner's Photo Gallery
I'm just guessing from the testimony, but it sounds like you swapped the head gaskets, maybe side to side? Ida know.. but it's easy to warp-up an aluminium head on an iron block from overheating. Since aluminium likes to soack up heat more that iron blocks, it could also damage the cylinder head in many other ways including valve guide seals. If your heads where sealed off from coolant circulation altogether, the temp gauge may never have shown you when the issue was getting really bad, and may have been heavily damaged.
Domesticon Prime
93' LE V-6, 303K Km., fully optioned including Leather Interior. ES300 rear discs, twin piston front calipers, Depo Chromes with HID projectors, 17" OZ' summer's, 96 corner lights, MAF, timing, exhaust and intake mods, 2001 Toyota/JBL sound, + more and always more coming.
Silent Runner is online now   Reply With Quote
Old 01-28-2011, 09:45 PM   #9 (permalink)
redneck engineer
lemegacool's Avatar
Gameroom cash: $233405
View lemegacool's Photo Gallery
i'm for cooked valve stem seal...
1994 camry v6 5 speed swapped
holset hx35w rebuild/polishing in progress :P
cardomain: http://www.cardomain.com/ride/3872430
lemegacool is offline   Reply With Quote
Tags
oil burning consumption
