1993 5SFE - will timing belt failure damage engine? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-27-2011, 03:29 PM   #1 (permalink)
View nemodat's Photo Gallery
1993 Camry LE 4 cyl auto, 354k km.
I've heard you need to replace the timing belt on this engine before it goes, because if it does break in operation it could/will damage the engine. (The Haynes manual is *very* clear that changing the timing belt is expert territory and damage will result if you screw it up.)
Could someone please confirm?
Thanks,
ND
nemodat is offline   Reply With Quote
Old 01-27-2011, 03:33 PM   #2 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
no, it won't break the engine. 5s-fe is a non-interference engine, you won't bend valves if that happens while driving.
if you have a garage then you could attempt changing it yourself, it takes about 8 hours the first time (if you never did that before) when you tackle the water pump and crank & cam seals, tensioner (plus spring) and idler pulley as well.
search forum or check Camry FAQ sticky on top, there is a few DIY's on that.
The Following 2 Users Say Thank You to fenixus For This Useful Post:
LynchburgCSI (01-27-2011), nemodat (01-27-2011)
Old 01-27-2011, 04:19 PM   #3 (permalink)
Freakin Scooters
LynchburgCSI's Avatar
Gameroom cash: $1409695
iTrader Score: 16 reviews
354k kilometers = 219.965402k miles. Go ahead and change it if it's in your budget. But yes, all of the camry engines from 92-01 are non interference.
'07 Honda Ruckus Big Bore
The Following User Says Thank You to LynchburgCSI For This Useful Post:
Old 01-27-2011, 07:36 PM   #4 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
As said, 5SFE is a non-interference engine. The only danger is stalling in front of a big rig truck! Not too safe.
Also, it helps to rig up the cam/crank pulley holder tools in the following thread from Home Depot parts. And get other necessary tools from Harbor Freight when on sale if you don't have them. For example, various torque wrenches.
home made tool to tighten camshaft sproket nut
Thanks,
ND
Tags
change, damage, engine, timing belt
