Anybody here change out an oil pan on a 3VZFE V6? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-27-2011, 03:40 PM   #1 (permalink)
Gameroom cash: $302547
View ricamryman's Photo Gallery
3rd Generation Anybody here change out an oil pan on a 3VZFE V6?
The last time I had my oil changed at FireStone they had advised me that my oil pan had a leak, they showed me while on the lift, & I saw a minute trickle of oil from the side of the oil pan that faces the dash board, not the front end. Today speaking with my Independent Mechanic who used to be a Toyota Tech told me that my 1993 V6 oil pan uses a silicone oil seal & is next to imposible to leak. I told him that I already did the valve covers & distributor O-ring so its not those items. He seems to think its the oil pump gasket leaking onto the pan, what do you guys think?......
ricamryman is offline   Reply With Quote
Old 01-27-2011, 03:42 PM   #2 (permalink)
3rd Generation
Also if it is indeed the pan, if I use a gasket instead of a silicone sealer, do I actually have to remove the exhaust pipe from under the pan, or is there enough wiggle room to get it out & in?.....
Old 01-27-2011, 04:10 PM   #3 (permalink)
Freakin Scooters
LynchburgCSI's Avatar
Gameroom cash: $1409695
iTrader Score: 16 reviews
Where's Eengineer, 2wickedtoys and rapeacivic when you need them?
'07 Honda Ruckus Big Bore
Old 01-27-2011, 09:42 PM   #4 (permalink)
71Corolla's Avatar
Gameroom cash: $548250
View 71Corolla's Photo Gallery
You will need to remove the Y-pipe to remove the oil pan. Which means removing it from both manifolds, and from the catalytic. I just pulled one off at the wreckers because mine has a dent in it. It's not a hard job if the manifold and CAT bolts/nuts come off relatively easily. Otherwise you could be in a world of hurt trying to get them out. Whatever you do, don't strip the nuts on the manifold, they will be very hard to remove if you do.
Once you get the exhaust out of the way, you remove the rear engine brace and the oil pan bolts/nuts and carefully pry it off. Going by what I saw at the wreckers, the sealant can indeed degrade over time, the pan came off pretty easily. When applying the RTV, get yourself the version in a caulking tube, doing by hand from a squeeze tube will be messy and not yield good results.
But make sure it is actually leaking from the pan before you go through all the trouble.
71Corolla is online now   Reply With Quote
Old 01-27-2011, 11:50 PM   #5 (permalink)
Bdub215's Avatar
Gameroom cash: $315565
View Bdub215's Photo Gallery
Yea FIPG rarely ever leaks and by that I mean design flaw or previous tampering. Op just make sure you don't have an oil leak running down onto the pan. That ypipe is a PITA.
93 Lexus ES300 5spd I/E URSB
Bdub215 is offline   Reply With Quote
Old 01-28-2011, 07:20 AM   #6 (permalink)
3rd Generation
You are right! Thanks because I am not adding a drop of oil between 3K mile OCI! The level on the dipstick is always at proper range! But however I have been adding power steering fluid, ie. Dextron 3 to the resevoir on occasion. ........
