Radiator Support - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-29-2011, 12:11 AM   #1 (permalink)
View kelley5795's Photo Gallery
Radiator Support
Does anyone know how hard it is to take off the Radiator Support And install A new one and also replace the bumper?
I have a Camry book but I'm not understanding it,1998 Toyota camry ...4C
kelley5795 is offline   Reply With Quote
Old 01-29-2011, 09:34 AM   #2 (permalink)
Operator / Diesel Tech
Mister_Perkins's Avatar
Gameroom cash: $601601
iTrader Score: 6 reviews
Yeah its pretty easy man. All you need is a cut-off wheel, a drill, and a couple hours.
Drill out where the welds are Filled in, and use a cut off wheel to cut through the support.
With everything removed on the car, cut it off. After you cut it off, all you do is weld it in place.
easy as 1-2-3
The Following User Says Thank You to Mister_Perkins For This Useful Post:
kelley5795 (01-29-2011)
Old 01-29-2011, 07:38 PM   #3 (permalink)
Could hounding give me a more step by step of how to take the bumper fully off Amd the RAF support and put everything back on right
Old 01-29-2011, 07:57 PM   #4 (permalink)
I dont think there is a DIY on how to do it for the camry.
Basically, remove the radiator / fans, cruise contol, battery, headlights / corner lights / bumper lights, front grille, bumper cover, a couple bolts that hold the bumper onto the car .. drop the bumper, remove both fenders, grab a cutoff wheel and a drill and cut your old support out. Straighten your body if bent at this time. After everything is straight, dry fit it and make sure its going to work. Tack it in place in a couple spots, and re-check for squareness. If good, continue to weld the rest of the core support in place. Make sure to put something fire retardant over the motor / anything you dont want to catch fire when grinding and welding. dont go crazy with the welding. All you have to do is fill in where the Factory spot welds are. If you use the tool listed at the bottom, it will leave you a large enough hole to tack it back together.
EDIT:
You will also have to remove the AC Radiator too
EDITEDIT:
This tool also comes in handy when removing the core supports
http://www.harborfreight.com/3-8-eig...ter-95343.html
Old 01-29-2011, 09:05 PM   #5 (permalink)
Ph thanks that helps alot but not real sure where the bolts that hold the bumper Inplace are at..... Another useful hints you could maybe give me to make it easyier... Because I know somewhat about cars but just needed some help, how long should this take?!?
Old 01-30-2011, 08:44 AM   #6 (permalink)
Probably take you about 10 hours removing everything and re-installing it since ur a first timer.
I'm sorry if I am not much more help, but there isn't really any documentation online so I am just telling you how to do it with text. I could go outside and rip my front end off and take pictures but theres nothing wrong with my car so it would be pointless.
Just take your time, and use the tool I listed to remove the spot welds.. Once you get all the welds ground and drilled out the support will simply fall off.
Since its a 4th gen, I'm not completely positive how to remove it. Once you get it down to the radiator support though, it comes off exactly the same.
You may want to look into getting a haynes manual or some sort of repair manual.
Old 01-30-2011, 11:22 AM   #7 (permalink)
Oh I understand, but I have the Camary book that the dealer uses to fix the cars Amd it shows how the rad support comes off but there are so many points that it shows, could I maybe send it to you and you point them out ?!? I would be really grateful if so
Old 01-30-2011, 12:11 PM   #8 (permalink)
Yeah Post it up
Old 01-31-2011, 11:36 AM   #9 (permalink)
Freakin Scooters
LynchburgCSI's Avatar
Gameroom cash: $1409695
iTrader Score: 16 reviews
Just as a reminder, FSM links are NOT allowed.
'07 Honda Ruckus Big Bore
