Indicator lights ON with a strange combination
Hi,
My 2000 Camry LE, has suddenly started showing the following symptoms. Not sure what needs to be done. If I take it to a dealer what should I expect?
1. When the car is started, the Engine Check light is ON. The only other light ON is the parking gear indicator ( the green P).
2. As soon as I press the brake pedal to change the gear, the “Replace Bulb” indicator comes ON and stays ON. I checked the front and rear lights, indicator/ break lights and they are working fine.
3. Once I put the car in the Drive gear, I don’t seen any gear lights (P, R, D, 2) on the panel.
4. The reverse gear indicator ( R ) comes ON, every time the brake pedal is pushed.
Thanks,
MG.
