01 camry problems - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-29-2011, 02:45 PM   #1 (permalink)
The Original Weasel
View ChitownCamry01's Photo Gallery
Angry 01 camry problems
ok i half assed search the forums but i need direct help. rocking an 01 camry auto w/ 2.2l. for some reason now the fuel and temp gauge aren't working, and i also cant get cruise control. looked and a bunch of different fuses but nothing blown. any idea what could be wrong? i feel like this cars a curse...
Dream as if you'll live forever, live as if you'll die today
ChitownCamry01 is offline   Reply With Quote
Old 01-29-2011, 06:06 PM   #2 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
Have you checked the 10A Gauge fuse? And the 15A ECU fuse? Does the cruise control light come on?
Swap with another fuse even if it looks fine. Or use a new one and see if it makes any difference.
Old 01-30-2011, 12:13 AM   #3 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
fried ecu.... just saying, they do stupid things like this
^ and leaving it that way!
Old 01-30-2011, 12:29 AM   #4 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
it could be electrical in nature. you could also check ground points in cabin, there is like 5 or 7 of them all in dash area. one of them might be loose.
check this:
http://www.toyotanation.com/forum/sh....php?p=3230226
Old 02-02-2011, 12:44 AM   #5 (permalink)
The Original Weasel
ok update; replaced all fuses, didnt change anything. Cruise control light does come on, but doesnt work. Checked grounds, all good. Any other ideas? how would i know if ECU messed up? nothing else acting up to my knowledge yet
Old 02-02-2011, 01:56 AM   #6 (permalink)
抵抗は無駄です
fenixus's Avatar
I doubt ECU has anything to do with fuel level and dash temperature gauge sender. ECU uses different sensor for monitoring the coolant temperature.
have you tried removing the instrument cluster from dash and checking plugs on the back?
