Speed Sensor Replaced... Still get Check Engine Light
Its a 1996 Camry LE I-4 with 99K miles.
I replaced the speed sensor. Disconnected, then reconnected the battery. The farking light went back on with the same code!!!
edit: Again with the bumping after 3 hours?! Calm down with that man! It's a forum, not the customer service department at the dealer.
'07 Honda Ruckus Big Bore TOTALED: '03 Ford Expedition Eddie Bauer 4x4 5.4L, '96 Camry LE 5S May '10: '11 Sienna V6 XLE FWD 8-pass. July '10: '06 Matrix XR Auto FWD Oct. '09: '05 RAV-4 L 4WD
Where is he? I demand a response. It's been 2 hours.
Another few ideas... reset the light again and see if it comes back on. If it does, i'm guessing something with the signal the sensor is sending. Maybe a bad waveform. Did you compare the resistance of the old sensor to the new one just for giggles?
I don't like P0X00 codes. Too general. To check the wave form you'd need a lab scope. Perkins, help?
You'll definitely need some kind of scope to check the wave forms. You'll need something like PICOScope, or a brand similar. Your Waveforms while watching should be in a Box type shape and all the same. You will be monitoring the Voltage, and the Frequency (Hz). As long as they are uniform, its working properly. May want to unplug the Speed sensor and unplug the harness from the computer and using a digital multimeter with continuity make sure that the wire is solid (not broken). If it has Excessive Resistance, its probably exposed to the elements causing the high resistance. You will need to find where the split or exposed wire is and repair it.
yeeeeaaahhhhhhhhhhhhh.....
Wanna buy a Camry? Either that or Im taking that bulb out.
$2500
