Trouble removing "lock up" solenoid SL - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-31-2011, 10:05 AM   #1 (permalink)
View awmccready's Photo Gallery
I removed the electrical plug and two bolts to what I believe is the "lock up" solenoid SL (E) just behind the park/neutral switch on my 1997 toyota camry le 4 cylinder automatic. However, I cannot seem to pull out the solenoid from the body of the transmission. My understanding has been that it was removable from the outside of the transmission without having to remove the oil pan to disconnect it on the inside of the transmission.
Any help would be appreciated.
awmccready is offline   Reply With Quote
Old 01-31-2011, 10:24 AM   #2 (permalink)
Operator / Diesel Tech
Mister_Perkins's Avatar
Gameroom cash: $601601
iTrader Score: 6 reviews
the SL Solenoid has a rubber O-Ring on it that may be stuck. Try putting a flat head screw driver underneath it and Prying on it gently. It will come out
If you place the screw driver on the side where the 10mm bolt is supposed to go, you can pry up there, and then switch to the opposite side and keep working it
Old 02-03-2011, 06:28 PM   #3 (permalink)
View jintag's Photo Gallery
Lock-up solenoid problem
Hi,
Did you get DTC P07733 on your code reader? I have a 1995 V6 LE and I got this code, which points to the same cylinder you are having trouble with. Did you ever get your problem resolved? Do you have a pic of where this part is? I'm having trouble finding it. How did you test it to verify that it was bad.
Thanks in advance for your help.
jintag
jintag is offline   Reply With Quote
Old 02-03-2011, 06:39 PM   #4 (permalink)
Originally Posted by jintag View Post
Hi,
jintag
Remove the SL Harness plug, and probe the single pin with one lead on the multimeter and probe the other pin to the transmission as a ground and measure for resistance.
Specs:
11–15 ohms of resistance
Location: (You may have to remove the Neutral Safety Switch to gain good access to the SL Solenoid)
Old 02-04-2011, 06:22 PM   #5 (permalink)
Lock-Up Solenoid
That pic is a huge help. Thank you so much for posting it.
jintag
Old 02-04-2011, 06:23 PM   #6 (permalink)
no problem
Old 02-04-2011, 07:30 PM   #7 (permalink)
Lock-Up Solenoid
Hello again. I checked my transmission and that plug is not where it is in your pic. I have a couple of pictures here. Do you know which one of these, if any, is the lock-up solenoid?
http://postimage.org/image/2nhpkoykk/
http://postimage.org/image/2nhr88b2c/
http://postimage.org/image/2z4jjk76s/
The 2nhpkoykk image is the park/neutral position switch looking from the front of the car from the ground.
The 2nhr88b2c image is looking from the top, it is the connector just to the right of the starter. almost smack in the middle of the image.
The 2zz4jjk76s image is looking from the top, this connector is located just above the steering rack at the edge of the transaxle near the firewall.
Thanks again in advance for your help.
jintag
Old 02-04-2011, 08:44 PM   #8 (permalink)
Oh whoops. Yeah, the 3rd and 4th gen transmissions are not the same. lol .. my bad!
the SL solenoid will be a single wire Connector (should be anyways)
one of the 4th gen guys might have to chime in on here
Old 02-04-2011, 08:57 PM   #9 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
pics embedded for easier viewing
I don't know much about it, I think the last pic shows the VSS sensor (connector with bolts). I don't have much idea about shift lock solenoids for transmission on gen4 unfortunately...
Old 02-04-2011, 10:21 PM   #10 (permalink)
lock-up solenod
ok. Thanks for your help anyways. I hope someone with my same vehicle year and type can help.
Thanks.
jintag
Old 02-04-2011, 10:31 PM   #11 (permalink)
71Corolla's Avatar
Gameroom cash: $548250
View 71Corolla's Photo Gallery
The FSM says to simply remove the 2 bolts and withdraw the solenoid. I would say the O-ring has welded itself to the body.
2000 Lexus ES300 Millenium Edition 1MZ-FE 64,000 Km
1993 Camry V6 LE 3VZ-FE 164,000 Km SOLD but still in the family
1990 Camry LE 2VZ-FE 202,000 Km
1987 Camry LE 3S-FE 435,000 Km
1971 Corolla 2-door Coupe 2T-C 260,000 miles
71Corolla is online now   Reply With Quote
Old 02-04-2011, 10:39 PM   #12 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
Can you take a picture from the top, aim at right behind the neutral safety switch.
Old 02-04-2011, 10:48 PM   #13 (permalink)
lock-up solenoid
hosting images
this is the best pic I have. I have to remove the cruise control stuff to get a better shot. But I don't see anything that looks like the figure in the FSM.
Old 02-04-2011, 11:02 PM   #14 (permalink)
This is the wrong location. Please refer to the diagram posted by 71. Please show a picture to help confirm it. (there is no need to remove anything)
Old 02-05-2011, 04:07 AM   #15 (permalink)
Gameroom cash: $422950
View Stillrunning's Photo Gallery
I wonder if someone used an additive that swelled the seals?
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
Tags
"lock up", removal, solenoid sl (e), transmission
