Eh, the CPS wouldnt cause your car to smoke badly. If your CPS was bad, it would either start up and shut down quickly .. or like in most cases, just not start at all.
Have you tried to spray any starting fluid on the motor while its running? It sounds more like a Large vacuum leak rather than a CPS problem. If it is a large vacuum leak your car would try to compensate for the outside air entering assuming its getting more air and adjust your fuel mixture rapidly causing the smoke.
Other things that could cause it to run crappy would be the Throttle position sensor (not being able to tell what position the throttle was in), MAP / MAF sensor wiring bad or sensor dirty.
Basically, I would look at the stuff you removed when you had the head off.. Making sure everything is hooked up correctly. Are you by any chance throwing a code?
What color is the smoke when running? Black or white?
