Fuel Gauge not working on 92' Camry CSi Sedan - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-01-2011, 01:30 AM   #1 (permalink)
View speckyboy's Photo Gallery
I just bought a 1992 Toyota Camry CSi Ltd Sedan a week ago. I found out that my Fuel gauge isn't working. After filling up a full tank of fuel, the fuel gauge needle still shows well below empty. I need to know what to do to solve the problem and how to go about solving it. Help is much appreciated!
speckyboy is offline   Reply With Quote
Old 02-01-2011, 04:26 AM   #2 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
check your fuses if all good there time to take a look at the sending unit, lift up the back seat (bottom part) and you should see a black access panel remove that and disconnect the connector there, and test the sending unit (search the site for how your going to need a ohm meter (or mulitmeter)) good there you need a new cluster or there wiring issues, bad then your going to have to get a new sending unit where to install that disconnet the gas lines and remove the panel there and pull it out it going to be a unit thing with the sending unit and fuel pump, if your going this far also pick up a new strainer screen and if you want to spend the money a fuel pump too (might as well since you got it out)
^ and leaving it that way!
