96 camry transmission not going forward - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-03-2011, 05:39 PM   #1 (permalink)
View rayrayb74's Photo Gallery
I have a '96 Camry 4 cylinder . The car will work in reverse, but won't work in Drive at all. Started a couple days ago tranny would get to high rpm then finely shift. Had a code scanner on and got a P0500 code<speed sensor>. would this sensor cause the car to not drive. thanks
rayrayb74 is offline   Reply With Quote
Old 02-03-2011, 07:27 PM   #2 (permalink)
A camry n00b
peshwa's Avatar
Gameroom cash: $257859
View peshwa's Photo Gallery
Bad speed sensors could cause transmission issues. Can you try putting the shifter in 2 and L gears? What happens? When was the transmission serviced? What color is the fluid?
Also are you mechanically inclined? Maybe a visit to a car salvage yard (pick and pull) could yield a used speed sensor. Should be couple of bucks max. Try swapping it out with your current one.
Do you have the camry manual with you? Find them here http://www.t u r b o n i n j a s .com/camry/
If transmission has not been serviced in a while I would drop the pan and change out the transmission filter (a small pickup screen).
Hope that helps!
1995 Camry DX L4 178,6XX miles and counting each mile.... acquired 05/25/2007 at 129K miles
2004 Mazda6 I4 5-Speed Manual 115,500 miles acquired 01/21/2011 at 109,XXX miles
peshwa is offline   Reply With Quote
The Following User Says Thank You to peshwa For This Useful Post:
rayrayb74 (02-03-2011)
Old 02-03-2011, 08:07 PM   #3 (permalink)
2 and L gears does nothing. Ive had the car a couple years and have not done no service to the tranny. Fluid look ok. I have a manual but i can not seem to tell were the sensor is from the pics they show. Ill try again when i get time. Thanks for the help
Old 02-03-2011, 08:51 PM   #4 (permalink)
71Corolla's Avatar
Gameroom cash: $548250
View 71Corolla's Photo Gallery
I don't know if this applies to your car, but on my 1993, when I disconnected the speed sensor the car drove but the speedo did not work (I only drove it less than a block).
2000 Lexus ES300 Millenium Edition 1MZ-FE 64,000 Km
1993 Camry V6 LE 3VZ-FE 164,000 Km SOLD but still in the family
1990 Camry LE 2VZ-FE 202,000 Km
1987 Camry LE 3S-FE 435,000 Km
1971 Corolla 2-door Coupe 2T-C 260,000 miles
71Corolla is online now   Reply With Quote
Old 02-03-2011, 09:44 PM   #5 (permalink)
Chemist at Chevron
Gameroom cash: $314885
View bdy0003's Photo Gallery
delete
95 Camry LE I4 195k
bdy0003 is online now   Reply With Quote
Old 02-04-2011, 06:45 PM   #6 (permalink)
any one know where to look for speed sensor.
Old 02-04-2011, 07:27 PM   #7 (permalink)
Operator / Diesel Tech
Mister_Perkins's Avatar
Gameroom cash: $601601
iTrader Score: 6 reviews
the only thing a bad speed sensor would do on the 92-96 camry is make it go into Limp mode (It would shift erratically)
I would get a pressure Gauge and test how much pressure your transmission is putting out
Old 02-06-2011, 09:59 AM   #8 (permalink)
A camry n00b
peshwa's Avatar
Good point Perkins and 71 Corolla. OP did you try resetting the code and disconnecting the battery and see if the code returns? Also what other codes is the ECU throwing? Did some incident trigger this code? Tell us more about the car so TN can help you.
Old 02-06-2011, 04:35 PM   #9 (permalink)
i did not reset code. there is no other code. car ran fine until day before it stopped. had bad shifting, high rpm to get it to go.next day would no longer go forward. yesterday changed tranny filter and new fluid. got it to go forward with high rpm but almost did not make it back from down the block...
Old 02-08-2011, 10:16 AM   #10 (permalink)
Old 02-08-2011, 11:25 AM   #11 (permalink)
Chemist at Chevron
Is this an automatic or manual transmission?
I'm thinking shift solenoid.
95 Camry LE I4 195k
Old 02-08-2011, 11:48 AM   #12 (permalink)
automatic. by the way i found speed sensor.
Old 02-08-2011, 12:48 PM   #13 (permalink)
Sounds like you have a Direct Clutch issue. There was another member on this forum who had the exact same problem, and he said it was his Direct Clutch. He actually installed the clutch packs in wrong too, so he had to re-do it twice. lol.
If you have any doubt, bring your transmission to a certified transmission shop and have them diagnose the exact problem with the transmission.
