New struts - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-04-2011, 06:54 PM   #1 (permalink)
View Ryan01le's Photo Gallery
New struts
My 01 Camry needs new struts. i Dont want the same floaty boaty stock feel, i wanna tighten up the handling. i dont wanna lower. anyone got any suggestions for what brand struts would give me the sportier tighter feel?
Ryan01le is offline   Reply With Quote
Old 02-04-2011, 07:10 PM   #2 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
Tokico HP struts, new OEM mounts and rubber parts, you can probably re-use stock OEM springs.
or if looking for a cheap get away go with Gabriel Ultra struts, they seem tighter/stiffer than OEM. Some say KYB are stiffer too ... but also OEM is supposedly the KYB actually, so I am not sure.
Old 02-04-2011, 08:02 PM   #3 (permalink)
Freakin Scooters
LynchburgCSI's Avatar
Gameroom cash: $1409695
iTrader Score: 16 reviews
^ +1.
/Thread.
'07 Honda Ruckus Big Bore
Old 02-04-2011, 08:06 PM   #4 (permalink)
Chemist at Chevron
Gameroom cash: $315385
View bdy0003's Photo Gallery
KYBs are stiffer than OEM. I would say go with KYBs if you're gonna go with stock springs. Also, you might wanna upgrade your RSB.
95 Camry LE I4 195k
bdy0003 is online now   Reply With Quote
Old 02-04-2011, 09:59 PM   #5 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
Tokico HP (Blue)
Old 02-05-2011, 12:38 AM   #6 (permalink)
Tom 2000's Avatar
Gameroom cash: $201200
View Tom 2000's Photo Gallery
I replaced the struts on my '00 Camry with KYBs 2 years ago. Also changed the mounts, and all the miscellaneous rubber pieces. Feels a lot tighter.
I did the job myself and ordered everything on-line. The mounts and rubber parts from an on-line Toyota dealer and KYB struts from eBay.
Tom
2004 Prius Touring Edition
2003 Corolla Luxel
2000 Camry LE - Lunar Mist Metallic
Tom 2000 is offline   Reply With Quote
Old 02-05-2011, 12:48 AM   #7 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
Originally Posted by LynchburgCSI View Post
^ +1.
/Thread.
not so fast, getting a set of solara SE springs or gen3 camry SE springs will tighten up the suspension more and not screw with ride height. mix that with the tokicos and youll have a pretty good ride. and id vote no to the KYBs, they are too close to stock to really have much of a noticable difference on stock springs.
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 02-05-2011, 02:20 AM   #8 (permalink)
Freakin Scooters
^ I'd never thought of that before, Rob. That's actually a REALLY good idea with the springs.
Old 02-05-2011, 02:38 AM   #9 (permalink)
Chemist at Chevron
I beg to differ. I have KYBs on mine and I notice a huge difference. If I had to do it again, Tokicos would have been better (my parents paid so I felt bad for spending their money).
If you're looking to sell or dont want to dump loads of money in your car, or know that your camry is on its last legs (like that will really ever happen) get the KYBs. If you want to lower, make more sporty, keep your car til it dies, get the Tokicos. They have a life time warranty. Only thing KYB has over Tokicos is that its 100+ cheaper.
95 Camry LE I4 195k
Old 02-05-2011, 02:42 AM   #10 (permalink)
Freakin Scooters
Errr. You're probably just noticing the difference between blown struts vs new ones. I'm still 100% unsure if they're firmer than OEM struts... but it's something to consider.
Old 02-05-2011, 02:54 AM   #11 (permalink)
Chemist at Chevron
After inspecting all four of the old ones, only one was blown and they rode like a boat whether going left or right. Also, bounce test was pretty inconclusive.
O well, we DIY for the experience, which is why I do preventative maintenance so they don't have a chance to fail on me later.
Edit: My 03 Camry rides like a boat too and so far it has 60k. So my guess is Toyota designed these things for comfort. I can feel a lot of the road on KYBs.
95 Camry LE I4 195k
Old 02-05-2011, 03:02 AM   #12 (permalink)
Gameroom cash: $422950
View Stillrunning's Photo Gallery
++^My 4 strut replacement experience with KYB was not good, not so much for the sturts but for the hardware, poor quality and tolerances. I would not buy KYB again (Keep Your Bilsteins) as if they cheap out the hardware I have no confidence in the strut quality. Replacing blown struts with anything will give remarkable new feel, but I'd steer clear of KYB.
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
Old 02-05-2011, 08:35 AM   #13 (permalink)
Lighting Specialist!
iovaykind's Avatar
Gameroom cash: $480582
iTrader Score: 8 reviews
View iovaykind's Photo Gallery
Not sure if this is a concern, but IIRC someone tried to use Tokico blues with OEM springs and they didn't fit? Or was it OEM springs with lowering springs, I forget which. Actually, it makes more sense that the springs were too short for OEM application, so I think you'll be good to go. My recommendation is the Tokicos with SE springs, so that ride height doesn't change but you're not having a floaty car. Also realize that if the tokicos ever blew you have warranty.
iovaykind is offline   Reply With Quote
