Camry Bulb chart 97-99 only - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-04-2011, 11:43 PM   #1 (permalink)
TN の がしょう
xpeed's Avatar
Gameroom cash: $589157
iTrader Score: 7 reviews
View xpeed's Photo Gallery
4th Generation Camry Bulb chart 97-99 only
Hey all. Since there isn't an actual thread with a list of bulbs for the Gen 4 Camry model year 97-99 here's the list I've gathered up. They're also similar to the 00-01 model years but the only difference is the headlights which are 9006/9005s I believe. It's pretty much accurate compared to the one you see on the owner's manual.
High & low beam headlamp
9003/HB2
Parking light
1157A
Front turn signal
1157A
Rear turn signal
3157
Tail light
3157
904
Stop light
3157
High mount stop light
921
License plate
2825
194
Back up light
921
Front sidemarker
1157A
Rear sidemarker
194
Glove box
37
Dome light
DE3175
You can also use any universal festoon adapter for LED pads.
Step/Courtesy light
DE3021
Trunk/Cargo area
194
Instrument-general
194
74 (These are for the smaller bulbs for the bottom portion such as seatbelt, warning lights, check engine, etc.)
The required voltage is pretty much in the owner's manual, but if you guys also need that, I'd be happy to provide that too.
1997 カムリ 5-spd *daily driver* Tokico HP - Tein S-Tech - TRD Kit - TRD FSB - ARC - 18" Enkei OR52 - Project Kics R40 - Custom Exhaust - Whiteline 20mm Rear Sway Bar
2003 Infiniti FX35 Sport Package - Metallic Copper
1996 Avalon MCX10 1MZ-FE
http://www.cardomain.com/ride/3900268/1997-toyota-camry
xpeed is offline   Reply With Quote
Old 02-04-2011, 11:50 PM   #2 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
It's missing fog lights. I believe camry's use H3 (solaras use 9006, different fogs).
Also, since Solara is actually Camry Solara I'd like to update the headlights bulbs for them:
Solara Headlights:
(gen1.0) 99-01 high/low 9003/HB2/H4
(gen1.5) 02-03 low 9006 / high 9005
Solara fogs:
99-03 - fog lights 9006
the rest is pretty much same (would need to double check though).
... in case someone was looking for it here.
Old 02-05-2011, 12:25 AM   #3 (permalink)
Freakin Scooters
LynchburgCSI's Avatar
Gameroom cash: $1409695
iTrader Score: 16 reviews
http://www.sylvania.com/ConsumerProd...lacementGuide/
PS- 1999 should be the same as the 97-98 models. The 00-01 are possibly different though.
'07 Honda Ruckus Big Bore
Old 02-05-2011, 12:44 AM   #4 (permalink)
TN の がしょう
xpeed's Avatar
^ Ah that's right. I kept thinking the 4.5 started at 99 and up.
Old 02-05-2011, 02:21 AM   #5 (permalink)
Freakin Scooters
Thread title + your post fixed.
