Hey guys,
I ordered a Viper 211HV Keyless Entry System off of Amazon for $50. The reason why I got the Viper is because my driver side lock cylinder is dead after 17 years of use, and it is really inconvenient to walk through the snow when parking on the side of the road to unlock the car from the passenger side. So before I started I got the wiring diagram for my car (all 300+ pages) and a wiring diagram for the Viper system:
Located Here
I've got the system to respond to the actual remote (I hear the relay clicking) but it does nothing.
From what I understand, I need to send a signal to the door lock control relay located in between the chassis on the passenger side. I've tried tapping into the blue wiring harness/cluster located in the drivers kick panel that feeds into the driver lock/unlock switch but no dice... I just have the 12V+ constant (spliced into from a previous amplifier install) and ground (spliced into from the driver side kick panel) currently hooked up to it and tried running one wire at a time to the that wiring harness. The installation instructions in the pdf are really ambiguous but I don't blame them, as they list several different types of connections. I assume I am supposed to be using the Common Output as that is a (-) signal but I also know that 87 and 87a are very common relays. Am I missing something?
For those who cannot access the pdf for whatever reason:
(+) 12V CONSTANT POWER INPUT
(-) 200 mA SECOND UNLOCK OUTPUT
INPUT OF DOMELIGHT SUPERVISION RELAY #87
OUTPUT OF DOMELIGHT SUPERVISION RELAY #30
LOCK #30 COMMON OUTPUT
LOCK #87 NORMALLY CLOSED
LOCK #87 NORMALLY OPEN (INPUT)
UNLOCK #30 COMMON (OUTPUT)
UNLOCK #87 NORMALLY OPEN (INPUT)
(+/-) PARKING LIGHT FLASH OUTPUT
(-) CHASSIS GROUND INPUT
(-) HORN HONK OUTPUT
FACTORY ALARM DISARM
(-) 200 mA CHANNEL 3 VALIDITY OUTPUT
(+) SWITCHED IGNITION INPUT (ACCESSORY)
(-) 500 mA GROUND-WHEN-ARMED OUTPUT
UNLOCK #87A NORMALLY CLOSED
(-) OUTPUT OF CHANNEL 2
Thanks in advance for your replies
PS: For those who are interested I can send over the whole wiring diagram pdf
