96 Camry heater/AC airflow stuck on bi-level - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-06-2011, 05:53 PM   #1 (permalink)
View ktnguyen's Photo Gallery
Hi
I have a 96 Camry V6 with 116,000 miles on it.
The heater control panels has 5 buttons for face, bi-level, floor, floor/windshield, windshield.
Right now it is stuck on bi-level no matter which button I push.
Can somebody tell me what is wrong with it ? Thanks.
ktnguyen is offline   Reply With Quote
Old 02-07-2011, 10:04 AM   #2 (permalink)
Operator / Diesel Tech
Mister_Perkins's Avatar
Gameroom cash: $601601
iTrader Score: 6 reviews
your Air Vent Mode Control Servo Motor is faulty and needs replaced
Edit:
Part number : 063700-3583
buy it now : http://cgi.ebay.com/ebaymotors/G3-92...item2a089856a8
Old 02-07-2011, 10:52 AM   #3 (permalink)
View iinh3's Photo Gallery
I had something similar on my 93 sedan. It turns out that the servo motor was fine, but some clip the connected the servo to the actual linkages controlling the damper had broken or come loose. I paid for a cheap part and a lot of labor to get it fixed. That was before I discovered TN. It would be a different story now.
iinh3 is online now   Reply With Quote
The Following User Says Thank You to iinh3 For This Useful Post:
Mister_Perkins (02-07-2011)
Old 02-07-2011, 11:01 AM   #4 (permalink)
It very well could be a linkage issue . That would be a nice, easy fix
Old 02-07-2011, 11:18 AM   #5 (permalink)
96 Camry heater control
Thanks for the reply, here is a pic of the control panel
The link to Ebay is for the servo motor for 4 cyl, would it work in my V6 ?
If the linkage is bad, how would I fix it ?
Thanks, I hope to keep this car for many years to pass down to my son
Old 02-07-2011, 12:22 PM   #6 (permalink)
It looks like you have an XLE Model .. the part number will be XLE / SE Specific:
Part number : 87106-33030
Price : $187.05
The 4/6 cylinder Heater controls should be the same.
Edit:
Keep in mind, your car VIN number can affect the part number as well (Vin # either starts with J or 4)
In short:
92-96 Camry 4 VIN
92-96 Camry J VIN
Best way to confirm which one you need is to call Toyota Directly, give them your VIN Number and tell them what part your looking for. They can give you part numbers. Gary on this forum can also get a discount on all OEM Parts too.
Old 02-07-2011, 04:32 PM   #7 (permalink)
Price : $187.05
Edit:
In short:
92-96 Camry 4 VIN
92-96 Camry J VIN
Thanks Mr. Perkin for your answer, my VIN starts with 4, it was made in Kentucky.
The panel looks like a bear to remove too, with all the wires and cables, any chance of fixing it ?
Old 02-07-2011, 04:56 PM   #8 (permalink)
You should just have to remove the lower half of the dashboard.. Very Do-able yourself if you have a socket set, a couple screw drivers. Do you happen to have a repair manual to assist you in the removal process?
Old 02-07-2011, 05:24 PM   #9 (permalink)
Freakin Scooters
LynchburgCSI's Avatar
Gameroom cash: $1409695
iTrader Score: 16 reviews
Perkins... the XLE was the only model with that HVAC setup. The SE matched the LE and DX models. But yes, the linkages do loveeee to come undone.
'07 Honda Ruckus Big Bore
Old 02-07-2011, 05:42 PM   #10 (permalink)
Oh my bad, I knew my XLE has the same Heater controls so I assumed it was in the SE As well
Old 02-07-2011, 06:05 PM   #11 (permalink)
redneck engineer
lemegacool's Avatar
Gameroom cash: $233405
View lemegacool's Photo Gallery
my LE has the exact same heater panel... its a j vin thought
1994 camry v6 5 speed swapped
holset hx35w rebuild/polishing in progress :P
cardomain: http://www.cardomain.com/ride/3872430
lemegacool is offline   Reply With Quote
Old 02-07-2011, 06:08 PM   #12 (permalink)
hmm .. Well to be exactly sure, call your dealer / parts department and give them your VIN #. They will tell you the exact part # you need.
I guess that it depends on where it was manufactured and what Options your car has whether it has that Heater Control vs. the other style
Old 02-07-2011, 11:51 PM   #13 (permalink)
Freakin Scooters
Canada spec LE's and LE Sports had them because there was no XLE for the Canadian market. I forget there's other places outside of America.
Old 03-04-2011, 08:55 PM   #14 (permalink)
Price : $187.05
Edit:
In short:
92-96 Camry 4 VIN
92-96 Camry J VIN
I replaced the control with a used on from Ebay, but it is still stuck on bi-level. So maybe it is servo motor or linkage. Any ideas where these things are located ?
I have a Haynes manual, but it does not say anything about those things.
Old 03-06-2011, 10:44 AM   #15 (permalink)
It could be, I removed the lower trim panel on driver side, then lower duct, but could not see the servo motor or linkage
