1992 Toyota Camry ruff idle - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-07-2011, 10:22 AM   #1 (permalink)
View mr.major's Photo Gallery
3rd Generation 1992 Toyota Camry ruff idle
Hello new to the forums. I have a 92 camry LE 4 cyl with 64,000 that i have had for about a year now and has been trouble free up until now. When i start the car it idles real ruff now and when when i put it in drive it bogs and also idles ruff and does not have the same power as it use to. Im not to mechanically inclined but would like to learn to do some maintenance on this car any help is appreciated.
mr.major is offline   Reply With Quote
Old 02-07-2011, 10:45 AM   #2 (permalink)
Operator / Diesel Tech
Mister_Perkins's Avatar
Gameroom cash: $601601
iTrader Score: 6 reviews
sounds like you could have more than 1 issue with your car, but I would start by cleaning your Idle Air Control Valve (IACV) and see if clears up your issue
DIY:
5sfe IAC Removal (lots of pictures)
Old 02-07-2011, 10:49 AM   #3 (permalink)
Thnaks for the reply it does'nt sound like a plug issue or wire issue to you?
Old 02-07-2011, 10:57 AM   #4 (permalink)
On the camrys, a very common thing to happen is the Emission system gets clogged up with carbon and sticks valves open causing the car to idle rough.
heres a video of my 1992 camry XLE With a stuck IACV:
You don't want to completely rule out other causes such as an Arching plug wire, Fouled spark plug, etc.. But its very common for an IACV to stick, or an EGR To stick on these cars.
If your curious about the ignition system, the spark plug wires should have 25 kohm Resistance, and the spark plugs should be gapped at 0.043 in.
Old 02-07-2011, 11:03 AM   #5 (permalink)
How much do you think a shop would charge to do this im not mechanically inclined at all?
Old 02-07-2011, 11:10 AM   #6 (permalink)
Well it depends on labor-rates. Some shops go by Flat Rate which means they go by what the Service book says as far as time it takes to do a job (Which a lot of times the book says more time or less time than it actually takes).
I would say it should take a competent shop about 60 minutes or less to remove / Clean / Re-install the IACV. I dont quite remember how much the Gaskets cost, but it shouldn't be more than $10.00 for parts.
I would say you could look to expect to pay around $70.00 - $100.00 for them to repair the IACV. Thats assuming that the shop is charging between $60.00 - $90.00 per hour.
Your best bet would be to go to a shop and tell them you want them to remove the Idle Air Control Valve and clean it and ask how much it would cost to do so.
Old 02-07-2011, 11:15 AM   #7 (permalink)
Ok i appreciate your help will get back with details
Old 02-07-2011, 11:33 AM   #8 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140495
if you give it a little throttle, does it smooth out?
Old 02-07-2011, 12:44 PM   #9 (permalink)
Gameroom cash: $303755
You could try cleaning the throttle body and idle air control valve yourself while it's still on the car. It's pretty easy to do yourself with spray throttle body cleaner. Here's a DIY tutorial on cleaning it on the 4 cylinder 5SFE engine.
How to: Cleaning Throttle Body -4 Cylinder Engines- With Pictures
Mike
