i need a new thermostat right? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-07-2011, 06:00 PM   #1 (permalink)
redneck engineer
lemegacool's Avatar
Gameroom cash: $233405
View lemegacool's Photo Gallery
Question i need a new thermostat right?
been like that for a while did not thought it was abnormal... the pic was taken after a 45min ride with me accelerating like a mofo
so? i need a new tstat right?
1994 camry v6 5 speed swapped
holset hx35w rebuild/polishing in progress :P
cardomain: http://www.cardomain.com/ride/3872430
lemegacool is offline   Reply With Quote
Old 02-07-2011, 06:09 PM   #2 (permalink)
Avy
Gameroom cash: $818555
View pmesfun's Photo Gallery
Seems like it, does the gauge go back to 1/2 after idling for a while?
99 Avalon XLS-149k
07 Avalon Touring-71k
99 Lexus LS400-88k
04 Nissan Quest-111k
pmesfun is online now   Reply With Quote
Old 02-07-2011, 06:11 PM   #3 (permalink)
redneck engineer
lemegacool's Avatar
nope! stays pretty much there...
that would kinda explain my crappy gas mileage... kinda
Old 02-07-2011, 06:20 PM   #4 (permalink)
View HotrodLSV8's Photo Gallery
Check coolant level first. But probably a good idea to replace the Tstat if it hasn't been done recently.
HotrodLSV8 is offline   Reply With Quote
Old 02-07-2011, 06:23 PM   #5 (permalink)
Avy
haha...lead foot
Yeah, just get an oem thermostat with o-ring, also the o-ring for the inlet pipe.
99 Avalon XLS-149k
99 Lexus LS400-88k
Old 02-07-2011, 06:32 PM   #6 (permalink)
71Corolla's Avatar
Gameroom cash: $548750
View 71Corolla's Photo Gallery
Yep you need a new thermostat. Needle should be near the halfway point, say 45%. When I bought my '93 it had the exact same problem, temp gauge stayed about where yours is.
2000 Lexus ES300 Millenium Edition 1MZ-FE 64,000 Km
1993 Camry V6 LE 3VZ-FE 164,000 Km SOLD but still in the family
1990 Camry LE 2VZ-FE 202,000 Km
1987 Camry LE 3S-FE 435,000 Km
1971 Corolla 2-door Coupe 2T-C 260,000 miles
71Corolla is online now   Reply With Quote
Old 02-07-2011, 07:00 PM   #7 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
yep...new thermo for sure.
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 02-07-2011, 07:05 PM   #8 (permalink)
redneck engineer
lemegacool's Avatar
coolant is full and its been at least 2 years for the tstat so yeah i'm doing it anyway...
haha...lead foot
how cant you have a lead foot with a v6 5 speed
i'm going to go with a aftermarket tstat as i will change it again this summer for a lower temp one for the supercharger...
the only reason why i want to change it now is that i want more heat in the cabin!!! also it must not help with mileage and performance...
going to change the coolant too with pretty oem red coolant
thats what i thougt! thanks!
Old 02-07-2011, 07:09 PM   #9 (permalink)
Avy
Make sure it has the jiggle valve, and its positioned at 12 0'clock, or else you have the same problem. In fact in my case OEM was cheaper than aftermarket. So check prices first.
99 Avalon XLS-149k
99 Lexus LS400-88k
Old 02-07-2011, 07:15 PM   #10 (permalink)
redneck engineer
lemegacool's Avatar
well my buddy who works at toyota ordered me one this morning lol he just told me
Old 02-07-2011, 07:19 PM   #11 (permalink)
Avy
Sweet!
99 Avalon XLS-149k
99 Lexus LS400-88k
Old 02-07-2011, 07:39 PM   #12 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
Pull the temperature gauge sender at the water outlet pipe and see if the gauge shows full hot.
Besides coolant level also double check the reading of the ECT sensor. Take an ohm reading and look it up on the chart for the temperature. If it's low it's the t-stat.
Old 02-07-2011, 07:58 PM   #13 (permalink)
sexy, dirty, and slow...
93XLEcamry's Avatar
View 93XLEcamry's Photo Gallery
sorry op to thread jack, but mines doesnt even go up....im guessing i need new ones too??
93XLEcamry is offline   Reply With Quote
Old 02-07-2011, 08:32 PM   #14 (permalink)
You mean the temp gauge doesn't move? You have to check the gauge first.
For example, pulling the connector at the gauge sender unit on the water outlet should make the needle peg to full hot. If it doesn't do that check the gauge circuit.
Old 02-07-2011, 08:41 PM   #15 (permalink)
93XLEcamry's Avatar
yea the temp gauge used to go half way like normal, then got lower and now it just stay down, doesnt even go up when warm...so i dont know if my car will overheat...lol...and where are the guage circuit and connector???mine is a 93 camry
