01 solara 2.2 starting problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-07-2011, 08:51 PM   #1 (permalink)
View aggarjr's Photo Gallery
i replaced the head gasket on it due to water pump seizing up and chewed up the timing belt too. replaced everything and tried to start it and it wont fire up. the engine cranks, it has spark, fuel, compression(150-180 across) timing is on point, camshaft timing too. i have a cel but i scanned it, no codes showed up. i know injectors are spraying because i had someone crank it while holding the injectors/rail and and sprayed amazing. now i dont know what else to do at this point. everyone that looked at this are speechless too. need help
aggarjr is offline   Reply With Quote
Old 02-07-2011, 09:06 PM   #2 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
Double check spark plug wire connections to the right locations. Flooded engine?
Old 02-07-2011, 09:14 PM   #3 (permalink)
yeah i check and they are in the right place. and i checked if it was flooded. and its not
Old 02-07-2011, 09:18 PM   #4 (permalink)
71Corolla's Avatar
Gameroom cash: $548750
View 71Corolla's Photo Gallery
Any way you can upload a video? Sounds like you have the bases covered, but hearing/seeing the engine cranking would really help.
2000 Lexus ES300 Millenium Edition 1MZ-FE 64,000 Km
1993 Camry V6 LE 3VZ-FE 164,000 Km SOLD but still in the family
1990 Camry LE 2VZ-FE 202,000 Km
1987 Camry LE 3S-FE 435,000 Km
1971 Corolla 2-door Coupe 2T-C 260,000 miles
71Corolla is online now   Reply With Quote
Old 02-07-2011, 09:29 PM   #5 (permalink)
i can but its gonna have to be done tomorrow cuts its already late/dark outside but i will try ti find a way to load it up here
Old 02-07-2011, 09:46 PM   #6 (permalink)
One owner recent had a similar problem. Turned out the cam was aligned to the wrong mark.
