99 Camry - Help with Transmission codes/parts - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-08-2011, 11:42 PM   #1 (permalink)
View truxor's Photo Gallery
Hello. I recently took my 1999 Camry to AAMCO to get my transmission checked and according to their report three codes came up PO750, PO755 and PO770.
I was trying to do some google searches, but since I don't know much about cars I was a bit confused on where to start. The guy was quoting me $2000 for everything, but I felt that that was a rip off. Is there anyone here that can help me understand those codes better and what parts I should be looking for and the range if possible. I would like to do some research on it and try to get a lower quote from other repair shops since I'll know what I'll be looking for and talking about.
Thanks a lot
Report reads: Our report revealed that the transmission fluid level is ok and the condition is with a burnt odor. Will not shift out 2nd gear. A computer scan revealed the following codes: PO750, PO755, PO770.
truxor is offline   Reply With Quote
Old 02-09-2011, 12:42 AM   #2 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
The A140 transmission has 3 shift solenoids. All three are bad at once? It is electrical? When was the last time you had the transmission serviced?
I'd contact a local ATRA transmission rebuilders assoc member shop for an opinion:
http://atra.com/shopfinder
It's possible that the internal parts wore out and plugged up the solenoids. If that's the case you likely need a rebuild. However, some shops do put in a "low mileage" (relatively speaking) salvaged transmission but may not tell you. It's much cheaper. See also:
Transmission Swap Write-Up and Photos
If you want a better reman transmission then check Jasper or Marshalls, typically with 3-year/100K mile warranty:
http://www.jasperengines.com/transmissions.php
http://www.marshallengines.com/transmissions.htm
Thanks a lot
