map sensor interchangeability - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-11-2011, 01:42 PM   #1 (permalink)
View eclypseballoons's Photo Gallery
help. I need to replace my map sensor because it was dammaged physicaly while doing some other work.
I cannot afford to buy a new one right now for over $225, but there are several listed online for $30 that say they will work, however the numbers do not match exactly.
they look the same physicaly, but mine has the number 89420 06010 and the closest I can find is 89420 06020.
will these interchange?
eclypseballoons is offline   Reply With Quote
Old 02-11-2011, 02:11 PM   #2 (permalink)
Operator / Diesel Tech
Mister_Perkins's Avatar
Gameroom cash: $601601
iTrader Score: 6 reviews
Should work.
I have a spare Map sensor if your looking for one that works if your car is 3rd gen.
the mounting bracket is broke, but the sensor is still good. Let me know if you want it, I could send it your way for $10.00 Shipped
Old 02-11-2011, 02:27 PM   #3 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
there is at least one dealer that publishes such information on internet.
go here:
http://www.trademotion.com/partlocat...?siteid=215498
type the part number of your MAP in search box and select Toyota and search. In results on right you will see all Toyota models and years having the same part.
Old 02-11-2011, 02:33 PM   #4 (permalink)
Heres them side by side. The 89420 06010 is the large one, the 89420 06020 is the small one:
The wiring harness plugs right into both of them, and the car runs with either / or
The large on above is the one I was talking about $10.00 shipped also. As you can see the one mounting tab is semi-broken
Edit:
In the mail 4 you
