headlight shutoff question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-11-2011, 04:30 PM   #1 (permalink)
Gameroom cash: $192100
View SexieWASD's Photo Gallery
My old Camry (96 4d 4cyl) would shut off the headlights when you opened the drivers door. I found out today that my same year wagon v6 does not. I'm thinking that the door opens headlights go off feature is part of the VIP alarm that the four door has, but the wagon does not have. Can anyone confirm that?
If that is the case did the wagon ever come with the VIP system? I'm pretty sure the cabin wiring harness is completely different, but if it was an option I may be able to switch it over to the wagon without some major hacking involved.
SexieWASD is offline   Reply With Quote
Old 02-11-2011, 04:33 PM   #2 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
nope i have no alarm and mine shuts off, make sure when the drivers door is open the open door light is on the dash. i had to replace my door switch recently (same year)
^ and leaving it that way!
Old 02-11-2011, 06:04 PM   #3 (permalink)
Thats actually what got me think ing that it was the alarm, I tested it after work and the dash light came on and it did not shut off the lights, so the door switch is working.
Actually now that i'm thinking about it I don't remember the door chime working either though. I didn't really notice because removing the peizo was the first thing I did when I got the four door.
Old 02-11-2011, 07:23 PM   #4 (permalink)
Lighting Specialist!
iovaykind's Avatar
Gameroom cash: $480582
iTrader Score: 8 reviews
View iovaykind's Photo Gallery
The headlights only turn off if it happens in this sequence: Car is on, turn off car, then open door. If your lights are on when the car is off and door is open, closing and opening again won't turn it off. Nor will having the doors closed, having headlights on while car is off, and opening door.
In short, only when the car is on, then turned off, will the headlights turn off when doors open. Safety feature obviously, to keep from dead batteries.
iovaykind is offline   Reply With Quote
Old 02-11-2011, 08:30 PM   #5 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
as far as I know the head lights shut off is built into the lights wiring and not into a security device circuit.
as above, check your door Ajar switch (or whatever it's called). make sure the dome light comes up when you open the door.
also as above mentioned, car must be shut off first before opening the driver door for lights shut off to happen.
Old 02-11-2011, 09:12 PM   #6 (permalink)
Operator / Diesel Tech
Mister_Perkins's Avatar
Gameroom cash: $601601
iTrader Score: 6 reviews
The Wagon / Coupe / Sedan all have the same Circuit for Auto-Light off:
Old 02-12-2011, 06:15 AM   #7 (permalink)
I think that I'll have to check out the integration relay where the switch is working and the buzzer and light shutoff is not.
Old 02-12-2011, 08:56 AM   #8 (permalink)
I have my piezo buzzer removed lights still turn off. I wonder if theres something inside the integration relay that stopped working ?
Old 02-12-2011, 11:06 PM   #9 (permalink)
Freakin Scooters
LynchburgCSI's Avatar
Gameroom cash: $1409695
iTrader Score: 16 reviews
^ Nope. It's the door switch itself. They LOVEEEE to get gummed up and stop working. Common issue. Take it apart and clean things up.
'07 Honda Ruckus Big Bore
Old 02-13-2011, 02:38 AM   #10 (permalink)
Domesticon Prime
Gameroom cash: $206500
View Silent Runner's Photo Gallery
Its a good system, shut off the lights when you shut off your car, and close the door. I really hate some of the newer cars that seem to have 5-10, minute timers on this!? Anyone else find themselves in a parking lot facing some stupid car with its lights still on for no frigging reason, and blinding you as you try to back out safely from your own spot. The door switches love to gum up as said above.
Domesticon Prime
93' LE V-6, 303K Km., fully optioned including Leather Interior. ES300 rear discs, twin piston front calipers, Depo Chromes with HID projectors, 17" OZ' summer's, 96 corner lights, MAF, timing, exhaust and intake mods, 2001 Toyota/JBL sound, + more and always more coming.
Silent Runner is offline   Reply With Quote
Old 02-13-2011, 11:26 AM   #11 (permalink)
Freakin Scooters
^ My Expedition has a 10 second interval timer from key-off that goes up to 120 seconds. I leave it on 20 and call it day.
Old 02-13-2011, 11:58 AM   #12 (permalink)
the only reason I was thinking that is because he said his Open door light turns on when he opened the door, which means the Switch would be working
Old 02-13-2011, 12:10 PM   #13 (permalink)
Freakin Scooters
My door open light worked.... kind of. You may be onto something though.
Old 02-13-2011, 12:17 PM   #14 (permalink)
One thing you could try to do is next time you turn the camry off, open the door and fiddle with the door switch. Maybe it is messed up, but working good enough to indicate the door is open ?
