At my wits end--2000 Toyota Camry LE - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-12-2011, 03:29 PM   #1 (permalink)
View camryguy89's Photo Gallery
Canada At my wits end--2000 Toyota Camry LE
My Camry, in the past year, has seemed to fall apart...I managed to figure out the issue with the EGR valve, but now the car is leaking gas like a faucet...I can't seem to win...anybody know if there is a common area for these cars to leak. I had the fuel filler neck replaced a while back and now this...all I can hope for is that the tank is still good.
camryguy89 is offline   Reply With Quote
Old 02-12-2011, 04:32 PM   #2 (permalink)
Operator / Diesel Tech
Mister_Perkins's Avatar
Gameroom cash: $601601
iTrader Score: 6 reviews
Do you know where your leak is coming from?
Fuel usually will leak where its pressurize. Mainly towards the Back tire, where the fuel lines are exposed. Thats the most common place for them to burst, right where it goes from under the car to the tank.
You almost will never see a return line Splurge fuel everywhere. Although, it does happen sometimes. Just turn the Key to the ON position without turning the car on and see if you have fuel spilling out. This will confirm a Main fuel line leak.
Old 02-12-2011, 04:33 PM   #3 (permalink)
ok, quick update, took the car to a service station and had them hoist it up. The lines are good, but the tank is not. It is pouring out gas from the seam...anyone had experience with this before and how much it cost? BTW the car is a 4 cl with a 5sfe engine.
Old 02-12-2011, 04:36 PM   #4 (permalink)
Hey Mr Perkins, yes the leak, is coming from the tank. on the passenger side. I did check all of the fuel lines for any pinches or rust and they actually seemed to be in excellent shape...the tank however...
Old 02-12-2011, 04:37 PM   #5 (permalink)
wow, that was quick . lol
Tanks are easy to replace. You can get them pretty cheap
A couple straps, a couple lines, a couple hoses, a connector and your done
Looked it up .. You may be able to find it cheaper elsewhere:
http://www.autopartswarehouse.com/de...QRB576959.html
On a side note, Im jealous because you guys have bigger tanks than my 3rd gens. lol
Old 02-12-2011, 04:41 PM   #6 (permalink)
haha ya, I did my update the same time you posted your first reply! Ok, thanks for the tip that is a great help!
Old 02-12-2011, 04:44 PM   #7 (permalink)
Hardest part on that whole job is removing the filler neck from the tank.
Old 02-12-2011, 04:49 PM   #8 (permalink)
Well it shouldn't be too bad as I had that replaced about a month ago...should slide right off! lol
Old 02-12-2011, 04:53 PM   #9 (permalink)
If you just replaced it I wouldn't buy a new one. Bring it to a professional welder and have them weld it for you.
Don't try to weld it yourself
Old 02-12-2011, 05:00 PM   #10 (permalink)
I didn't replace the tank, just the neck...its not welded on the tank, but is connected to the tank by pressure fittings on a flexible tube.
Old 02-12-2011, 05:02 PM   #11 (permalink)
my bad, I thought you said you just replaced the Fuel tank. haha.
Your fuel tank should last a very long time.
if you want it to last a very very long time, ask your mechanic to under-coat the tank before installing it
Old 02-12-2011, 05:08 PM   #12 (permalink)
Thanks for the tip! Thats a good idea haha...I love the car just hate all its little quirks...but as far as engines go, this one, at 230,000kms is as quiet as it was when it left the showroom floor! Thanks for all the help and advice...if you have more, it is all welcome!
Old 02-14-2011, 09:14 PM   #13 (permalink)
Boy, do I have a laugh for you guys. So this afternoon, I started pricing out gas tanks to replace my leaky one. I first went to NAPA...can't get it, so i went to another parts store and got a quote for $420. I almost hit the roof. So I went home and called the stealership and they quoted me $916.91 for the tank. When he said that I almost threw the phone in disbelief. I then called a third place called 'tanks unlimited,' and got a quote for the same tank (new) of $205.00. Add another 20 bucks on that for shipping and then HST...it was a little bit over $250. Small price to pay for a good tank. The best part is, its under a lifetime warranty and will be here tomorrow morning. Thought I would share.
In case anyone is curious, I live in Nova Scotia, Canada
