Help! Windows won't roll up - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-13-2011, 07:42 PM   #1 (permalink)
View LeArN2LiVe's Photo Gallery
Hi, just received a 92 Camry XLE as my first car and am in the process of fixing the little things that are wrong with it. First off, the day I received the car the windows were functioning properly but strangely all of the buttons on the driver side controls are no longer functioning. I can't lock the car doors nor roll up the windows. The other window switches on the car also do not function anymore. Any idea which fuse it may be?
Thanks in advance everybody!!
LeArN2LiVe is offline   Reply With Quote
Old 02-13-2011, 08:15 PM   #2 (permalink)
Gameroom cash: $115825
View abew330's Photo Gallery
first welcome to TN!
be sure to check out the FAQ and what not at the sticky threads at the top
make sure you check all common fuses under hood and behind coin tray on driver side.
what else thats power isnt working?
theres a green fuse thats behind the dash under the steering column.
you need to remove like 4 10mm bolts to access the fuse.
its just above and to the right of the fuse block thats behind the coin tray
The Following User Says Thank You to abew330 For This Useful Post:
LeArN2LiVe (02-13-2011)
Old 02-13-2011, 08:36 PM   #3 (permalink)
Thanks, it was a fuse.
Old 02-13-2011, 08:38 PM   #4 (permalink)
Avy
Gameroom cash: $818555
View pmesfun's Photo Gallery
Sweet!
Simple fixes are always great.
99 Avalon XLS-149k
07 Avalon Touring-71k
99 Lexus LS400-88k
04 Nissan Quest-111k
pmesfun is online now   Reply With Quote
