Need info on TRD EBC and ECU of gen4 s/c cars
Okay gen4 guys who are supercharged I need your info for creating a circuit to control the EBC of the trd supercharger to modify it for a gen3. I need to know what kind of voltages are being given out of the ECU at pin 11 of connector E10 (The wire that is grounded on the EBC when you have a manual transmission). It's a air-fuel sensor map out of the ECU and I need to know what the EBC detects. (0-5V with 0V at shifts?)
This data will make possible for any gen3 to use the TRD EBC on an automatic transmission since I will build a circuit that is controller by microprocessor to detect the gear changes and cut boost at every gear change.
1994 Camry Wagon LE V6 Supercharged at 4-5psi (peaks at 5.25(6 in cold weather) w/Projector Headlights and no rust!
