98 Camry V6 Automatic transmission emergency - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-14-2011, 12:09 PM   #1 (permalink)
View IchibahnSLC's Photo Gallery
4th Generation 98 Camry V6 Automatic transmission emergency
I just started my car up after several months of sitting. Did a fluid change on everything and now the transmission is acting funny. It goes into gears fine but seems to sit in a higher gear in D. Slow to accelerate. I did notice that one of my connectors at the tranny is broken. I can't seem to find what it is nor a part number thru toyota.
Anybody know what it is and hopefully a part number?
It's what's circled in the red.
http://s258.photobucket.com/albums/h...icture_015.jpg
IchibahnSLC is offline   Reply With Quote
Old 02-14-2011, 12:21 PM   #2 (permalink)
wagonsrule's Avatar
Gameroom cash: $126000
View wagonsrule's Photo Gallery
Can't tell really by the connector photo but it could be a solenoid connector on the transmission. If it's solenoid number 1 you are stuck in 3rd gear that's why it's hard to accelerate.
Here's a link to the manual of the transmission
http://www.---------.com/camry/ax2.pdf
Go to page 98-103 and diagnose your problem.
it's turbo ninjas .com in one word(no spaces) for some reason i can't post link but it works type it up. Copy the link and write it instead of the ------'s
ALSO IF YOU PUT THE TRANS IN L mode you should be in first gear. In D and 2 you will start in 3rd
1994 Camry Wagon LE V6 Supercharged at 4-5psi (peaks at 5.25(6 in cold weather) w/Projector Headlights and no rust!
wagonsrule is offline   Reply With Quote
Old 02-14-2011, 12:27 PM   #3 (permalink)
I found the part number finally. Its called the transmission wire. Part number 82125-33010. If you google image it it will show a pic on a lexus website. looks like 3 seperate wires run from it inside of the tranny.
