93 V6 XLE Cluster Help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-15-2011, 11:19 PM   #1 (permalink)
View cobainfan68's Photo Gallery
3rd Generation 93 V6 XLE Cluster Help
I have a dummie question, I have a 93 V6 XLE Camry Automatic and the cluster is like dead. Only works the gas, temp and tach. I was searching to buy other one, but I don't know if it's the same cluster on the I4 models too. Can I use any cluster from a 92-96 Auto. model or it has to be 92-96 V6 Auto. models?
Thanks!
cobainfan68 is offline   Reply With Quote
Old 02-15-2011, 11:44 PM   #2 (permalink)
Gameroom cash: $202300
View zppeacock's Photo Gallery
What do you mean by "dead" no lights???....
zppeacock is offline   Reply With Quote
Old 02-15-2011, 11:51 PM   #3 (permalink)
71Corolla's Avatar
Gameroom cash: $548750
View 71Corolla's Photo Gallery
It's likely not the cluster that is at fault, much more likely a fuse, or bad connection to either the back of the cluster, or elsewhere. But if it is a failing cluster, you need one from a V6 not the I4. The clusters between the two are the same except the tachometer, if you put an I4 cluster into your car the tach will read too fast.
2000 Lexus ES300 Millenium Edition 1MZ-FE 64,000 Km
1993 Camry V6 LE 3VZ-FE 164,000 Km SOLD but still in the family
1990 Camry LE 2VZ-FE 202,000 Km
1987 Camry LE 3S-FE 435,000 Km
1971 Corolla 2-door Coupe 2T-C 260,000 miles
71Corolla is online now   Reply With Quote
The Following User Says Thank You to 71Corolla For This Useful Post:
cobainfan68 (02-16-2011)
Old 02-16-2011, 12:01 AM   #4 (permalink)
Sorry, the tach also don't work. I said like dead because the tach and speedometer doesn't work anymore. I don't know the speed i'm driving or the rpms. I buy a new speedsensor and the problem was not fixed. So, I guess the cluster is the problem. I saw few ones on ebay, but there are for 2.2 or 3.0 and I don't know if any of the same gen works.
Old 02-16-2011, 12:16 AM   #5 (permalink)
Thanks! I checked the fuses and they r ok, I'll check the connections. Also, the 92-93 cluster's are the same of the 95-96? Because I search and sellers distinguish the years, I believe they have to be the same.
Old 02-16-2011, 12:18 AM   #6 (permalink)
71Corolla's Avatar
Does the odometer turn? The first thing you need to check is the gauge fuse, if that's good then pull the cluster out and inspect the connectors to make sure they are plugged in properly. Failing that, the cluster itself could have a bad solder joint or other problem.
It is also possible that there is a bad ground somewhere in the harness but less likely. BTW, if you see an Ebay listing that shows compatibility for both that 4 and 6 cylinder, pretty sure this is wrong. I've put a cluster from a V6 into a 4 cylinder, and the tach worked but it shows too slow, idle was at about 400 rpm instead of the correct 700.
And I believe you need a cluster from a 1992-1993 only, not 1994 and up, but not 100% sure on this.
Old 02-16-2011, 12:26 AM   #7 (permalink)
71Corolla's Avatar
These might help, although I could not see in the manual which terminal exactly is B10.
Old 02-16-2011, 05:20 AM   #8 (permalink)
Tom 2000's Avatar
Gameroom cash: $201200
View Tom 2000's Photo Gallery
The 92-93 V6 clusters have a higher redline (6500 RPM) The later V6 models and the 4-cylinder models have a lower redline.
Tom
2004 Prius Touring Edition
2003 Corolla Luxel
2000 Camry LE - Lunar Mist Metallic
Tom 2000 is offline   Reply With Quote
The Following User Says Thank You to Tom 2000 For This Useful Post:
Old 02-16-2011, 01:52 PM   #9 (permalink)
3rd Generation
71Corolla thanks a lot, I'll check the cluster's connectors and wiring too. And yes the odometer turn. If i can't resolve the problem, i'll buy another one of the same model and year.
Old 02-16-2011, 02:00 PM   #10 (permalink)
3rd Generation
Thanks Tom, it's good to know there's a difference and what is. I'll make sure of that when I search other ones.
Old 09-10-2011, 02:29 PM   #11 (permalink)
View ScottForster's Photo Gallery
This is the exact problem I have been having... Thanks for FINALLY answering my questions
My Current "collection" :
1. 1996 Honda Civic EX Full B16B swap, many other mods
2. 1996 Toyota Camry XLE 3.0 V6, traded a 90 Golf for this beauty
ScottForster is offline   Reply With Quote
