Lately, my '99 I4 Camry has been losing coolant and I've been trying to find the source. At the last oil change a couple weeks ago, I saw old streaks of coolant running down the front of the oil pan so I followed the trace up to find this:
Close-up:
I think this is the location of my leak but not sure of how to stop it. I've changed the thermostat before but it looks like the leak is coming from that silver pipe--there isn't a seal there, is it? Any advice would be appreciated .
Seeing you have to drain the coolant, replace the thermostat and gasket at the same time. To replace all the O-rings, the water pump needs to be removed, so start with just the gasket and O-ring on the bypass pipe. There are I believe 2 bolts holding the bypass pipe that will have to be removed to give enough movement.
__________________ 2000 Lexus ES300 Millenium Edition1MZ-FE 64,000 Km 1993 Camry V6 LE3VZ-FE 164,000 Km SOLD but still in the family 1990 Camry LE2VZ-FE 202,000 Km 1987 Camry LE3S-FE 435,000 Km 1971 Corolla 2-door Coupe2T-C 260,000 miles
I would remove the Water by-pass hoses from around the filter and move the Coolant lines towards the drivers side.
The other way would be to remove the thermostat / waterpump and timing belt assembly.
Looks like I'm gonna try to do the first way, the latter is way too involving for my schedule and I don't want to have someone else do it. Hope it's not too difficult...
I've already replaced the thermostat last year when I replaced the radiator. Will removing just the two bolts give me enough room to work and finish up?
Not sure, I think so. You'll know, worst case if you will have to remove some other stuff on the drivers side to give you enough play to get at the O-ring.
Hi guys, back again. It looks like my leak isn't from the spot I originally looked at but rather further up:
Sorry for the weird mirrored picture but you can probably see the pink-ish buildup right under the alternator. I think that is the water pump--is it time to replace it?
+ 1 on the Waterpump leaking, sign of problems ahead. While in there, I would at the minimum put in a new timing belt if it hasn't been replaced already, along with the idler bearing, etc. Good luck on it.
