Sway bar bushing bracket - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-17-2011, 03:16 PM   #1 (permalink)
View twodoorcamry's Photo Gallery
Need a new sway bar bushing and bracket ("clamp", sway bar to subframe).
Searching for where to puchase them, it seems that the retailers are just selling bushing and bracket without specifying make and yearmodel... It will specify sway bar diameter, but how can I even know that the bolt holes on the clamp will fit? Seems risky... I dont want to buy the part, get under the car and find out that it wont fit...
Anyone had experience with this?
My car: a 94 camry LE
twodoorcamry is offline   Reply With Quote
Old 02-17-2011, 03:24 PM   #2 (permalink)
Chemist at Chevron
Gameroom cash: $315485
View bdy0003's Photo Gallery
Did you try rockauto.com? Get Moog as everybody swears by them. I personally upgraded to a Whiteline RSB, which provided just the bushings.
95 Camry LE I4 195k
bdy0003 is online now   Reply With Quote
Old 02-17-2011, 04:57 PM   #3 (permalink)
View agni's Photo Gallery
For the bracket, your best bet would be the salvage yard. They would probably let you have it for free, or a couple bucks at the most. If its for the rear, be sure to pick it off of a 3rd gen as they are a bit shorter on the 4th gens, and won't fit. Not sure about the front though.
If the salvage yard isn't an option for you, Energy Suspension sells "universal" polyurethane bushings with the brackets. You can order a set here for a little under $20 shipped. Just make sure to get the right bar diameter, and check the hole spacing.
I also found the front bracket here. 8 bucks without shipping though.
agni is offline   Reply With Quote
Old 02-17-2011, 05:00 PM   #4 (permalink)
Operator / Diesel Tech
Mister_Perkins's Avatar
Gameroom cash: $601601
iTrader Score: 6 reviews
Get some thick metal and bend your own bracket/drill holes to hold it in place.
Old 02-17-2011, 05:10 PM   #5 (permalink)
Freakin Scooters
LynchburgCSI's Avatar
Gameroom cash: $1409695
iTrader Score: 16 reviews
Call the dealership. Or contact Gary (toyotapartsman?) and ask him. A set is something like $15 bucks.
'07 Honda Ruckus Big Bore
Old 02-17-2011, 05:23 PM   #6 (permalink)
Super Moderator
eyeball96's Avatar
Gameroom cash: $908127
iTrader Score: 59 reviews
I bought Gen 4 bushing brackets for my Gen 3.5 Coupe at the dealership when I had the TRD rear sway bar installed a few years ago.
IIRC they were only like 8 bucks each...I'm sure they cost more now, but I bet not much.
BTW The Gen 4 brackets are actually Larger than the ones on the Gen 3/3.5
96 Camry Coupe LE V6
98 Honda CRV
08 GMC Crew
11 Kia Sportage EX AWD
eyeball96 is offline   Reply With Quote
Old 02-18-2011, 01:40 AM   #7 (permalink)
Thanks all, I guess I will call up the dealer just to see what they charge.
The Junk Yard is burried under feet of snow here in New England so I dont think i feel up to that. But maybe I'll bring a showel and go there...
Old 02-18-2011, 07:09 AM   #8 (permalink)
Freakin Scooters
Twodoor... are you upgrading your swaybar or not? I can look up the part numbers if you'd like. Like eyeball said, the gen 4 ones are probably needed if you're moving to an upgraded bar.
Old 02-18-2011, 08:50 AM   #9 (permalink)
92 Camry 5S-FE
LittleWhiteBubble's Avatar
Gameroom cash: $115750
View LittleWhiteBubble's Photo Gallery
I got mine from autozone... surprisingly they had them in stock and in store. I got a box with the pair of them for around 9 bucks. The brackets I would agree, are a junkyard pick.
LittleWhiteBubble is offline   Reply With Quote
Old 02-18-2011, 12:01 PM   #10 (permalink)
Not upgrading. What happened was that the bracket on one side of the rear sway bar just fell apart somehow. Rust I guess. The sway bar is hanging down there and giving of a "clank" sound at some bumps.
About a month ago I had a snowplow hit my tail from the side. It impacted the rim and dented it, and it shredded a part of my bumper. We were equally at fault and I won't get anything from his insurance nor from my own because i really have no coverage.
Maybe the hit on the rim is what caused the sway bar to come of its bracket. But the "clank" sound only started about two weaks ago, so much later. Apart from the dent on the rim and a blister on the tire, the alignment seems fine, control arms and suspension looks allright.
Old 02-18-2011, 12:22 PM   #11 (permalink)
Freakin Scooters
Part number 48832-06010 for those brackets by the way.
Old 02-18-2011, 12:22 PM   #12 (permalink)
That is probably what happened as far as rust. Your more than likely going to have a hard time removing the mounting bolts connected to the body when you go to replace it.
Why dont you have insurance anyways? Thats kinda scary...
Edit:
Nevermind. you must have Liability
Old 02-18-2011, 01:42 PM   #13 (permalink)
So, the bracket is $9 at the dealer... Will get that one and pick up the bushing at autozone...
Can't belive i was going to such lengts to avoid the dealer when the part is so cheap anyway. I used to have an Audi and got used to calling the dealer always only as a last resort. Love buying parts for the Toyota (and replacing them).
Old 02-21-2011, 08:06 AM   #14 (permalink)
92 Camry 5S-FE
That's the upside to having a car thats 16 years old. A lot of the dealer parts for the gen 3 camry are cheaper just because they're going to phase out. Don't the dealers only have to stock parts for 10 years mandatory or something like that?
