adding pwr mirror - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-20-2011, 12:56 AM   #1 (permalink)
View carpetguy00's Photo Gallery
adding pwr mirror
So I got a Gentex mirror with temp and compass. Got the wire, mounted the temp probe. Anyone know an easy way to power it? what should i tap into, or do i add another fuse to the box? I dont think it uses much power..... I can wire it to a cig lighter adapter, but only want to use that temp.
On an unrelated issue: Today was the dreaded day: doing a drain/refill on the stepmom's 02 buick century. Of course there was no trans drain plug, so it was a friggin mess! To refill I used Valvoline synblend dex3 in the red jug. I added 4 qts, started to add the 5th when i realized it was the color of oil, not ATF, even tho the quart was labeled ATF. glad i was paying attention. Guy at the parts store confirmed it was oil...... LOL
97 Camry LE 5SFE 135k
94 Corolla 1.6 @ 215K
97 F150 xlt v6 120k
92 Accord 4cyl 127k (totalled 8.4.11 by semi)
carpetguy00 is offline   Reply With Quote
Old 02-20-2011, 01:08 AM   #2 (permalink)
Avy
Gameroom cash: $818555
View pmesfun's Photo Gallery
I think you could wire it to the map lights.
I wired my homelink garage opener to the constant radio power(with fuse)and no problems since.
99 Avalon XLS-149k
07 Avalon Touring-71k
99 Lexus LS400-88k
04 Nissan Quest-111k
pmesfun is online now   Reply With Quote
Old 02-20-2011, 10:21 AM   #3 (permalink)
map lights? I dont have map lights, and my dome light is above the backseat almost, since i have the (non power) sunroof. the closest would be the cig lighter or radio.
97 F150 xlt v6 120k
Old 02-20-2011, 11:20 AM   #4 (permalink)
The Tri-Camry Family
Yuko's Avatar
Gameroom cash: $260040
View Yuko's Photo Gallery
You can tap onto the lighter. Check if it's a constant 12V because some vehicles’ lighter only works with the ignition on making it a 12V ACC. When I install a Homelike mirror on my sister's Versa, I tap onto an empty slot on the fuse box, added a 10A fuse, and ran a 16GA wire in the A-pillar, behind the headliner to the mirror for the ACC 12V. But for my constant 12V, I tap on to the map lights with a 10A fuse.
Which every route you chose; remember to add fuses and joint all connections properly. Because the last thing you need is an electrical fire.
"Yūko" 2001 Camry 5S-FE/A140E @ 90k
"Sandy" 2002 Camry 2AZ-FE/U241E @ 156k
"Chihaya" 2012 Camry 2AR-FE/U760E @ 2K
Yuko is offline   Reply With Quote
