96 1mz timing belt - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-20-2011, 03:35 PM   #1 (permalink)
View faoc's Photo Gallery
96 1mz timing belt
trying to get new belt back on after replacing 3 seals, 2 cam seals and the crank seal. When pulleys and crak are lined up to marks the marks on new belt wont line up . Is it neccessary for the belt marks to line up or just the cam and crank pulleys ? Any help please>
faoc is offline   Reply With Quote
Old 02-20-2011, 04:15 PM   #2 (permalink)
Avy
Gameroom cash: $818555
View pmesfun's Photo Gallery
What belt is it? Toyota?
99 Avalon XLS-149k
07 Avalon Touring-71k
99 Lexus LS400-88k
04 Nissan Quest-111k
pmesfun is online now   Reply With Quote
Old 02-20-2011, 04:57 PM   #3 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
try switching sides of belt. you may have it left to right
Old 02-20-2011, 05:09 PM   #4 (permalink)
Avy
^good point, should look like this, label comes after the crank sprocket.
99 Avalon XLS-149k
99 Lexus LS400-88k
The Following User Says Thank You to pmesfun For This Useful Post:
tacosteelersman (02-24-2011)
Old 02-20-2011, 07:56 PM   #5 (permalink)
The belt is made by Dayco. Did try both ways with no luck, there are arrows on the belt which I have pointing inward towards engine.
Old 02-20-2011, 10:25 PM   #6 (permalink)
View dudutzu's Photo Gallery
you have it backwards, the narrows should be pointing away from the engine/towards the right fender of the car
the numbers tell you in which order to align the belt
Click this bar to view the small image.
dudutzu is offline   Reply With Quote
The Following 3 Users Say Thank You to dudutzu For This Useful Post:
faoc (02-20-2011), fenixus (02-20-2011), tacosteelersman (02-24-2011)
Old 02-20-2011, 10:32 PM   #7 (permalink)
That works. Thanks to all that replied.
Old 02-20-2011, 10:35 PM   #8 (permalink)
抵抗は無駄です
fenixus's Avatar
one picture worth more than thousand words
