Wow! I got lucky today! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-20-2011, 07:17 PM   #1 (permalink)
Gameroom cash: $302547
View ricamryman's Photo Gallery
3rd Generation Wow! I got lucky today!
After driving home from work, I noticed a small puddle of coolant comming from the passenger side right front end of the car tonight! So I put the car on ramps, get my flashlight and snoop around under the car to trace the leak. Turns out the leak was comming from under the upper radiator hose clamp that had come loose & the hose was backing off from the upper radiator inlet allowing coolant to leak out.! I loosened up the clamp, repositioned the radiator hose & tightened the screw type hose clamp back into the correct position on the radiator! I count my lucky stars as I checked the other radiator clamps! That would have been the kiss of death to my beloved 1993 134K mile 3VZFE V6 LE had that hose come off the radiator since my commute home was a 25 Mile highway run & I was driving around 65-70 MPH!........
ricamryman is offline   Reply With Quote
Old 02-20-2011, 07:26 PM   #2 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
good job, another camry saved
Old 02-20-2011, 09:22 PM   #3 (permalink)
Earning Stripes
TRD95's Avatar
View TRD95's Photo Gallery
Would of seriously hated for you to lose that wonderful 3VZ-FE engine. Glad you caught that just in time! I would replace that clamp if I were you. It may just back off again. Keep your eye on it!
Killed in action - 11/22/2011
Final Score - 355,202 Miles
Dynomax Exhaust | DEPO Clears | 8000k HID Kit | PIAA Fogs | Weapon R Intake | Optima Red Top | Brembo Front Rotors | TRD Grille | Potenza G19s | Koyo Radiator | Perma-Cool ATF Cooler | JVC Ipod & Bluetooth On Board |
TRD95 is offline   Reply With Quote
Old 02-20-2011, 09:27 PM   #4 (permalink)
Avy
Gameroom cash: $818555
View pmesfun's Photo Gallery
I would get the spring type clamps from Toyota. It will never come off then.
99 Avalon XLS-149k
07 Avalon Touring-71k
99 Lexus LS400-88k
04 Nissan Quest-111k
pmesfun is online now   Reply With Quote
Old 02-20-2011, 10:03 PM   #5 (permalink)
T100 Road Warrior...
BamZipPow's Avatar
Gameroom cash: $863210
View BamZipPow's Photo Gallery
You must've run over a radiator clamp fairy at some point in time. This was payback!
1998 T-100 SR5 2WD auto, Roadmaster Active Suspension, 6½" dropped front air dam, 4½" drop full belly pan, 4° rear diffuser, 11" side skirts, oil catch jar, AC mod, aero cap, 67% grill block = 26mpg highway!
Originally Posted by n c t t o r a
You have used a censored word. Please remove this word.
BamZipPow is online now   Reply With Quote
Old 02-20-2011, 10:10 PM   #6 (permalink)
redneck engineer
lemegacool's Avatar
Gameroom cash: $233405
View lemegacool's Photo Gallery
i think i'm going to replace my shitty hose clamps with stainless t-bolt clamps... just to be sure...
1994 camry v6 5 speed swapped
holset hx35w rebuild/polishing in progress :P
cardomain: http://www.cardomain.com/ride/3872430
lemegacool is offline   Reply With Quote
Old 02-21-2011, 04:49 AM   #7 (permalink)
3rd Generation
Do you have any pics of what those look like?.....
Old 02-21-2011, 05:05 AM   #8 (permalink)
View Kingdom934's Photo Gallery
it really pays to pay attention when you reverse or get out of a parking spot. If you see a puddle and it wasn't raining and not using AC, something might be wrong. I saved my now camry when my idiot uncle kept driving it with the water pump leaking (went bad)...It should have DAWN on him that if the car was running 'a little hot' while driving, wouldn't you go and CHECK on the coolant level OR at lease under the car?
Glad you did that. It saved your car, your engine...and perhaps wallet
'85 Camry DLX 158K
'87 Cressida 78K
'07 Nissan Versa 63K SD (traded in)
'10 Nissan Versa 26K HB (traded in)
'04 Camry XLE V6 52
Kingdom934 is offline   Reply With Quote
Old 02-21-2011, 04:57 PM   #9 (permalink)
redneck engineer
lemegacool's Avatar
they are uber expensive but they hold like a mofo!!! these clamps are commonly used on turbo piping
Old 02-21-2011, 05:17 PM   #10 (permalink)
3rd Generation
Yikes!.... Very cool!
Old 02-21-2011, 07:49 PM   #11 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
good save man.
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
