Wont fire up - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-20-2011, 07:56 PM   #1 (permalink)
View deejayphilo's Photo Gallery
Wont fire up
I have 93 Toyota Camry i just did the headgasket and timing belt today but after all that the car wont fire up...
deejayphilo is offline   Reply With Quote
Old 02-20-2011, 08:51 PM   #2 (permalink)
The Tri-Camry Family
Yuko's Avatar
Gameroom cash: $260240
View Yuko's Photo Gallery
I could be a number of things. Have up check the compression? After that, recheck the timing. I had the same problem right after I replaced the timing belt, the engine would turn over but won't start. Turns out I set the camshaft to the wrong timing mark.
"Yūko" 2001 Camry 5S-FE/A140E @ 92k
"Sandy" 2002 Camry 2AZ-FE/U241E @ 158k
"Chihaya" 2012 Camry 2AR-FE/U760E @ 6K
Yuko is online now   Reply With Quote
Old 02-20-2011, 08:54 PM   #3 (permalink)
redneck engineer
lemegacool's Avatar
Gameroom cash: $233405
View lemegacool's Photo Gallery
check your timing marks 1'st... is there spark?
1994 camry v6 5 speed swapped
holset hx35w rebuild/polishing in progress :P
cardomain: http://www.cardomain.com/ride/3872430
lemegacool is offline   Reply With Quote
Old 02-20-2011, 09:15 PM   #4 (permalink)
The timing is perfect...on TDC but i think there is no spark from d distributor
Old 02-20-2011, 09:16 PM   #5 (permalink)
Could it be the vaccum hoses..but i was thinking it should at least fire up
Old 02-20-2011, 10:03 PM   #6 (permalink)
redneck engineer
lemegacool's Avatar
check the rotor inside the dist.. then check the coil
Old 02-20-2011, 10:30 PM   #7 (permalink)
Gameroom cash: $123900
View dave1811's Photo Gallery
4th Generation
So, when you mean it won't fire up, you mean it's turning over, just not starting, right? You said the timing was right on. Was about the crank position sensor, did it get hooked back up, any wire split, etc? Are you getting spark, etc. More details......
99 Camry (141k miles-At the graveyard now!)
99 Camry (161k miles)
02 Sienna
dave1811 is offline   Reply With Quote
Old 02-20-2011, 10:56 PM   #8 (permalink)
No spark coz when I put my continuity tester with bulb its not lighted at least just a bit. There is no crank sensor though...the engine turns it just won't fire up.
Old 02-20-2011, 10:58 PM   #9 (permalink)
Where is the coil located at...
Old 02-20-2011, 11:03 PM   #10 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
4 cylinder or 6 cylinder?
Old 02-20-2011, 11:09 PM   #11 (permalink)
4 cylinder...
Old 02-21-2011, 01:37 AM   #12 (permalink)
Can anyone help me where the coil of my this car
Old 02-21-2011, 10:39 AM   #13 (permalink)
4th Generation
It should be under the distributor cap on the 93 5SFE.
http://www.utoyot8.com/FullImage.asp...9508)5SFE..NAP
It is part number 19500B (COIL ASSY, IGNITION, **919-02163) in the picture. I did the search on the 93 Camry Sedan 5SFE, NAP (North American Product) made. If yours starts with a J in the VIN number, it was made in Japan versus U.S. Verify the model, US made, etc. But it will give you an idea where it is.
Hope this helps,
02 Sienna
