If it's not the mounts, it could be a failing brake booster. Easy to check, disconnect the vacuum line to the booster and plug the hose. Set the parking brake, and shift through the gears. Be very careful when doing this, because you will have no brake assist! For extra protection, block the wheels.
2000 Lexus ES300 Millenium Edition 1MZ-FE 64,000 Km
1993 Camry V6 LE 3VZ-FE 164,000 Km SOLD but still in the family
1990 Camry LE 2VZ-FE 202,000 Km
1987 Camry LE 3S-FE 435,000 Km
1971 Corolla 2-door Coupe 2T-C 260,000 miles
