1999 auto transmisson fluid leaking from inspection cover, where is it coming from? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-22-2011, 01:33 AM   #1 (permalink)
View nogard's Photo Gallery
I know it isn't engine oil, it is transmission fluid. Would it be leaking from the Torque converter? Or from the transmission input shaft seal?
Anyone see this before? Looks like I not only have to flush and fill the trans fluid, but now I might have to drop the trans as well.
(Frustration!)
nogard is offline   Reply With Quote
Old 02-22-2011, 07:58 AM   #2 (permalink)
T100 Road Warrior...
BamZipPow's Avatar
Gameroom cash: $863310
View BamZipPow's Photo Gallery
How good are yer engine/trans mounts? Did you have any work done lately?
How good is yer ATF? You could try some Auto-RX and see if it stops the leak or not.
1998 T-100 SR5 2WD auto, Roadmaster Active Suspension, 6½" dropped front air dam, 4½" drop full belly pan, 4° rear diffuser, 11" side skirts, oil catch jar, AC mod, aero cap, 67% grill block = 26mpg highway!
Originally Posted by n c t t o r a
You have used a censored word. Please remove this word.
BamZipPow is online now   Reply With Quote
Old 02-22-2011, 08:33 AM   #3 (permalink)
Gameroom cash: $109000
View cf99's Photo Gallery
Are you sure it's not just leaking from a deteriorated gasket? Not sure anyone can tell you where it's leaking from without seeing it. Any chance you can post some photos? Try cleaning everything off so you have a clean baseline to try and judge the source.
cf99 is offline   Reply With Quote
Old 02-22-2011, 01:30 PM   #4 (permalink)
It won't be until this weekend I would have time to take some pictures. I know what you are saying it is hard to visualize.
It is leaking from inside the bell housing, behind the inspection plate (small moon shaped plate. This is a higher point than the pan gasket on the bottom (which is also leaking).
