Need Help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-22-2011, 04:49 PM   #1 (permalink)
View Steve Jones's Photo Gallery
Need Help
I have a 93 Camry and it has been stauling out on me at idle. I have changed all the spark plugs, wires, cap and rotor with no luck. it runns great at high speed but after it warms up and it comes back down to idle it stauls. any answers?
Steve Jones is offline   Reply With Quote
Old 02-22-2011, 05:19 PM   #2 (permalink)
Avy
Gameroom cash: $818655
View pmesfun's Photo Gallery
ECT sensor is probably faulty?
99 Avalon XLS-149k
07 Avalon Touring-71k
99 Lexus LS400-88k
04 Nissan Quest-111k
pmesfun is online now   Reply With Quote
Old 02-22-2011, 05:28 PM   #3 (permalink)
93 Camry LE 5S-FE
4Cyl'erThriller's Avatar
Gameroom cash: $428696
iTrader Score: 15 reviews
View 4Cyl'erThriller's Photo Gallery
Could be clogged injectors or bad fuel pump but I dont really know too much about that stuff. Other than electrical or fuel problems I dont see what else could cause that kinda problem.
4Cyl'erThriller is offline   Reply With Quote
Old 02-22-2011, 05:39 PM   #4 (permalink)
Gameroom cash: $303755
Try cleaning the throttle body paying particular attention to spraying the cleaner liberally down in to the square or diamond shaped port in the base of the throttle body. That port leads to the idle air control valve which may be dirty and causing your stalling. Spray the claenr down there first and let it soak while you go on to clean the rest of the throttle body. Here's a link to a DIY thread that shows how to do it on your 5SSFE engine;
How to: Cleaning Throttle Body -4 Cylinder Engines- With Pictures
Mike
Old 02-22-2011, 05:42 PM   #5 (permalink)
Thank you for the reply I will check the ECT sensor
Old 02-22-2011, 05:51 PM   #6 (permalink)
Mike thank you for the link, great detial, I think this could be the issue
Old 02-22-2011, 06:11 PM   #7 (permalink)
93 Camry LE 5S-FE
SeaFoam it!
If you dont know what this is search and you shall find..
