2001 burnt gauge cluster bulbs - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-22-2011, 10:45 PM   #1 (permalink)
View 99offroadrngr's Photo Gallery
4th Generation 2001 burnt gauge cluster bulbs
I'm new here and just got a 2001 camry with 201k miles for very cheap. About half of my gauge cluster isn't lit up and it looks horrible, even my "drive" indicator light on the left side of the cluster is burnt out. every other gear lights up except Drive since its the one thats used the most.
My question is, after i remove the two screws on the top of the dash, what do i do to access the rear of the gauge cluster? Also, are the bulbs themselves green or are they white/yellow? on my previous vehicle the bulbs were white and the overlays were painted green. I'm curious on that because I'll be swapping to LED's which will be brighter and last longer.
My floor shifter indicator lights are also out so if someone knows how to tackle that too that would be great.
Thanks.
01 Camry LE
99offroadrngr is offline   Reply With Quote
Old 02-23-2011, 12:31 AM   #2 (permalink)
MIK1989's Avatar
View MIK1989's Photo Gallery
Here are some DIYs for you:
1. *DIY* 97 Cluster LED Swap
2. Gen 4-4.5 DIY Changing your bulbs inside your center console
3. http://www.toyotanation.com/forum/t100756.html
The bulbs in cluster are clear, but they have green rubber over them. Be careful when removing it, if the bulbs are pretty old the rubber could stuck to them and may rip during removal.
Toyota Camry XLE 1997, V6 (1MZ-FE)
MIK1989 is offline   Reply With Quote
Old 02-23-2011, 08:15 AM   #3 (permalink)
Awesome, thanks for the links. I'll be doing this when the warmer weather comes!
01 Camry LE
Old 02-23-2011, 09:06 AM   #4 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
after you remove 2 philips screws (self tapping) from top, then you pull out the trim (it's just clipped in). the cluster itself i held by 4 smaller philips screws (regular), after removal and some wiggling and tilting you will eventually pull the cluster out (be creful not to damage wire plugs on back of it!)
the "green" bulbs are actually Toshiba 194/G9 bulbs (can be replaced by Sylvannia Silverstar 194LL) wearing a thin green rubber coats
you can easily replace them with LED clusters from sites like here in any color you like:
http://www.superbrightleds.com/cgi-b...ini-wedge.html
Thanks.
Old 02-23-2011, 09:34 AM   #5 (permalink)
Thanks man. I had LEDs from them on my last vehicle, I can't even count how many times i changed colors haha I just wasn't sure if it was similar taking the clusters out but it seems like it is.
My truck
final product with new cluster(i fixed the temp gauge lol)
helping a friend with his
01 Camry LE
Old 02-23-2011, 10:32 AM   #6 (permalink)
抵抗は無駄です
fenixus's Avatar
so it should be a piece of cake for you
Old 02-23-2011, 10:34 AM   #7 (permalink)
Yep haha.
01 Camry LE
