93 Camry XLE V6 Transmission jerks - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-23-2011, 04:18 PM   #1 (permalink)
View azcat90's Photo Gallery
3rd Generation 93 Camry XLE V6 Transmission jerks
My 93 Camry XLE V6 lurches forward too quickly when I shift to drive - I have to make sure I brake hard while shifting into drive so I don't lose control exiting my garage. Seems to have enough fluid in it - I just bought it in December so I don't know the maintenance history for the transmission - it has 130K miles. Any advice is appreciated. It has a 3VZ-FE engine and is Japan-built.
93 Camry XLE V6
00 4Runner Ltd 4WD
01 Sequoia Ltd 4WD
azcat90 is offline   Reply With Quote
Old 02-23-2011, 04:36 PM   #2 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
any issues in gear? low idle? sound?
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
The Following User Says Thank You to bigbird For This Useful Post:
azcat90 (02-25-2011)
Old 02-23-2011, 04:59 PM   #3 (permalink)
Avy
Gameroom cash: $818655
View pmesfun's Photo Gallery
I would start with draining and dropping the pan on the transmission and drain the differential. Get a filter kit(i.e. Wix) and drain fluid at every oil change, until red/clean.
99 Avalon XLS-149k
07 Avalon Touring-71k
99 Lexus LS400-88k
04 Nissan Quest-111k
pmesfun is online now   Reply With Quote
The Following User Says Thank You to pmesfun For This Useful Post:
Old 02-24-2011, 12:29 AM   #4 (permalink)
3vz-f[Turbo bitch]e
View khanhstar's Photo Gallery
Thumbs up
yo same car same engine same problem. solution.
check your idle. and your hoses going to you radiator
khanhstar is offline   Reply With Quote
The Following User Says Thank You to khanhstar For This Useful Post:
Old 02-25-2011, 07:39 AM   #5 (permalink)
It is idling at about 1300 when I first start it... I'll check it out.
93 Camry XLE V6
00 4Runner Ltd 4WD
01 Sequoia Ltd 4WD
Old 02-25-2011, 07:45 AM   #6 (permalink)
I don't notice any gear issues, shifting, etc... I was testing it yesterday and what it really does is hesitate for about a second after I shift from P to D before it enagages the wheels. I'm going to try checking the idle and the hoses going into the bottom of the radiator and also do the xmssion fluid - I'll have to educate myself on the differential thing.
93 Camry XLE V6
00 4Runner Ltd 4WD
01 Sequoia Ltd 4WD
Old 04-05-2011, 10:49 AM   #7 (permalink)
I dropped the pan and changed the gasket, filter cartridge and replaced the fluid that drained out. Thanks to NAPA guy for selling me the 10mm hex socket five minutes after they closed. There is some improvement. I think I can live with it now - I am going to drain and replace fluid again this weekend since it was so brown. It's also too high up the dip stick so I think I'm only going to put back 2 quarts this time. 3 quarts drains out when I pull the plug out. I'm told that too much fluid could blow the seals.
No idea where to find the differential - I looked but could not find the bolts shown on the toyotapartszone.com diagram.
93 Camry XLE V6
00 4Runner Ltd 4WD
01 Sequoia Ltd 4WD
Old 04-05-2011, 10:59 PM   #8 (permalink)
Domesticon Prime
Gameroom cash: $206500
View Silent Runner's Photo Gallery
Differential is the finned thin on the drivers side of the transaxle, to the right of the driverside axle housing. Drain is on bottom, filler plug a ways up on the side of the housing facing the back of the car. You will need you hex socket again to open the fill plug, and its a tight space. so a big socket wrench won't fit over it. I just used a small wrench on the hex part (and a hammer), to open it. You will also need a pump to refill it, or some tubeing to gravity feed the refill. Holds about 0.8 qts. Oh ya, careful not to drop all the washers into your drain pan like I did - got to do it twice.
Domesticon Prime
93' LE V-6, 303K Km., fully optioned including Leather Interior. ES300 rear discs, twin piston front calipers, Depo Chromes with HID projectors, 17" OZ' summer's, 96 corner lights, MAF, timing, exhaust and intake mods, 2001 Toyota/JBL sound, + more and always more coming.
Silent Runner is offline   Reply With Quote
The Following User Says Thank You to Silent Runner For This Useful Post:
azcat90 (04-07-2011)
Old 04-06-2011, 01:09 AM   #9 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
Just want to make sure it's check with engine running after shifting through all gears and end up in Park, right?
Too high an idle speed will do that, it's like you're stepping on gas while shifting.
Autozone shows 3.3 qts transmission and 1.5 qt differential.
The Following User Says Thank You to JohnGD For This Useful Post:
Tags
shifting, transmission, xlev6
