octane for 1MZ-FE engine - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-23-2011, 10:33 PM   #1 (permalink)
tylerho's Avatar
View tylerho's Photo Gallery
4th Generation octane for 1MZ-FE engine
You may get this question all the time but what octane should I use on my 1999 v6 camry. It already has 127,000 miles on it, recently i put in 89 octane gas from chevron with lucas oil fuel system cleaner. So should i stay with 89 or go to 91 octane. One more thing is arco/bp gas any good.
tylerho is offline   Reply With Quote
Old 02-23-2011, 10:37 PM   #2 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
stay with top tier gas stations and you will be OK. those would be all major fuel suppliers like Shell, BP, Exxon, Chevron and a few others uncommon to my region.
manual recommended is 91 octane to feel the full capabilities of V6 engine at its 10.5:1 compression ratio. but we all know that a wallet has a word to say too so any grade (never go below 87 though) will not harm it, it might just feel less powerful with 87 in tank.
I actually tend to fill my V6 up with Shell Premium fuel (93 octane in my area) to have some fun when I want to
The Following User Says Thank You to fenixus For This Useful Post:
tylerho (02-23-2011)
Old 02-23-2011, 10:43 PM   #3 (permalink)
Gameroom cash: $109000
View cf99's Photo Gallery
This is from the '01 manual but probably the same:
In some cities all gas stations get their base gasoline from the same pipeline, and then mix in their brand-specific additives. So if some gas is bad, all gas is bad.
cf99 is offline   Reply With Quote
Old 02-23-2011, 10:46 PM   #4 (permalink)
抵抗は無駄です
fenixus's Avatar
worth mentioning the RON calculated octane numbers are used in Europe (and Asia I think) while North America uses AKI calculated octane numbers.
so 87 AKI octane = 91 RON octane
and 91 AKI octane = 96 RON octane
Old 02-23-2011, 10:52 PM   #5 (permalink)
Avy
Gameroom cash: $818655
View pmesfun's Photo Gallery
I tried 93 for about 3 fill ups, but didn't notice any change in power or mpg. Also, gas prices are too high to use 93. Don't even put in a full tank anymore.
99 Avalon XLS-149k
07 Avalon Touring-71k
99 Lexus LS400-88k
04 Nissan Quest-111k
pmesfun is online now   Reply With Quote
Old 02-23-2011, 10:58 PM   #6 (permalink)
抵抗は無駄です
fenixus's Avatar
true, that's the wallet side of this story it's getting harder and harder for me too to stay with premium fuel on this car ... good thing I don't drive it too much, so can't feel the real problem.
my wife's 5s-fe runs on regular 87 fuel, she drives further distances daily than I do. ... but on weekends it's just pure pleasure for me to take V6 for a ride together and have that Hulk kick under my foot
Old 02-23-2011, 11:04 PM   #7 (permalink)
Avy
Yeah, I've been starting to drive aggressively when I get bored, but 80% of the time its 2500rpm or less.
99 Avalon XLS-149k
99 Lexus LS400-88k
Old 02-23-2011, 11:18 PM   #8 (permalink)
抵抗は無駄です
fenixus's Avatar
LOL, same here, I'd say even 99% of time I don't exceed 3k rpm (NJ traffic moves dynamically hehe).
now gas prices are getting jacked up again ... revolutions in countries having oil ...
Old 02-24-2011, 07:55 AM   #9 (permalink)
Have any of you guys ever checked mileage of using premium vs regular? I've heard it can make a small difference, but enough of one that it compensates for the added cost of premium (tho I guess that depends whether your most common premium is 91 or higher cost 93). Never checked myself.
If premium stays at a fixed amount above regular (91 premium is generally 20 cents above 87 regular in my area) it becomes less painful to buy, percentage-wise, as overall prices rise. Yeah I know, that's a stretch
Old 02-24-2011, 09:55 AM   #10 (permalink)
抵抗は無駄です
fenixus's Avatar
I believe the 1mz-fe (or any V6 for that matter) gets better MPG, if driven under same conditions, with premium fuel over the regular one.
another thing is that not everybody likes limited performance of 1mz-fe on regular fuel.
5s-fe (or any 4cylinder with 9.5:1 compression ratio) will rather only feel sportier (and not always) with better fuel, but you won't see any MPG improvement, so bottom line it's not worth it for those.
another thing is that 5s-fe engines are made to run best with regular 87 octane fuel and if actually yours is running much better with premium then it would be common to say your engine is out of tune as 87 should make it run at most optimal specs and MPG.
Old 02-24-2011, 10:30 AM   #11 (permalink)
1MZ powered MR2
Jason.MZW20's Avatar
Gameroom cash: $226450
View Jason.MZW20's Photo Gallery
Yeah, the 1MZ advances the ignition timing a bit more with 91 or higher. It makes the combustion efficiency rise. Anytime the ignition timing is retarded, efficiency of the engine falls as the fuel is ignited later in the cycle, which can waste gas. Knock corrections definitely cause poor efficiency since the timing is retarded to the "safe zone" point. Can be 5* BTDC or lower. I've seen as low as -12* BTDC.
The 5SFE has stunted ignition timing maps, so 87 is the best fuel regardless - unless you're experiencing knock.
1991 Toyota MR2 V6
Ported, rebuilt 3.0L 1MZ
Fully OBDII compliant and California smog legal
Jason.MZW20 is offline   Reply With Quote
Old 02-24-2011, 12:01 PM   #12 (permalink)
TN's Mad Chemist
projektvertx's Avatar
Gameroom cash: $568901
iTrader Score: 20 reviews
View projektvertx's Photo Gallery
I can confirm both points actually. MPG improvements, yes. Power, realistically, the number has been contested a lot. But there is a difference. This is the first gen 1MZ.
pmsfun, your car should be premium only. My mom has a 98 Avy, and the owner's manual calls for premium only (91 octane or greater). And I'm pretty sure I remember it being written on the fuel door too.
1995 Toyota Camry V6 LE-6M1 250K Miles, Fun Car
1997 Acura RL-Gone
2007 Acura RL SH-AWD, Technology Package, Opulent Blue Pearl- Fun Car/Daily Driver
projektvertx is offline   Reply With Quote
